Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 52
    7 Post(s)
    I don't see anything wrong w/those pistons
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. #17
    Oct 2012
    Moline, Illinois
    I love that sh*t!
    Thanks on the heads, got plenty of 809s laying around.
  3. #18
    Jan 2003
    aalsmeer
    any theory,s on why you would want to use the large dome heads instead of the small ones
    and you seem to have something in between
    Attached Thumbnails Attached Thumbnails Schermafdruk van 2014-10-24 22:27:56.png   Schermafdruk van 2014-10-24 22:27:01.png   Schermafdruk van 2014-10-24 22:26:03.png
  4. #19
    8 Post(s)
    I like the v4 shape better than any v6 head
  5. #20
    Jan 2003
    aalsmeer
    very curious about this
    Attached Thumbnails Attached Thumbnails 2stroketunershandbook.rotated.pdf   graham_bell_squishband.pdf
  6. #21
    8 Post(s)
    The pipe effects the sqiush band so we need a paper on outboards with very short megaphones
  7. #22
    May 2005
    Greenville, NC
    Quote Originally Posted by PanRonnie View Post
    Nitrous.
    Ló fasz racing
    Joe Horvath
  8. #23
    Jan 2003
    aalsmeer
    Quote Originally Posted by jphii View Post
    Nitrous.
    Would not the same theory apply
    minimise heat exposure to the piston crown?
  9. #24
    8 Post(s)
    strength?
  10. #25
    Feb 2006
    Cool
    can you edit the ecm for more fuel and revs?
    hi i also have etce with carbs and early ignition on it just brought if for another guy ran 87 mph towing 2 skiers on a 1750 bullet but had sport master gearbox on it
    does anyone run exhaust temp guages the only place to plump them in seems to be in the adaptor on the mid section
    the engines down here are running for an hour at a time so the tune is not as harsh as your drag engines
  11. #26
    Junk Pump fuel
    much bigger bore.
  12. #27
    8 Post(s)
    Quote Originally Posted by SPANNA View Post
    You can install them in adapters that replace the head bolts and they go straight into the port on a V6
  13. #28
    May 2001
    Hickory NC
    Head depth and width effect were the engines make power. Overly wide squish are also more detonation prone.
  14. #29
    Why run the open deck heads? Stoker told me to
  15. #30
    Jan 2003
    aalsmeer
    and yet strangely the 225 heads from 94 to 98 have the 436892 part number wich would be the small dome head?
    this is of the BRP website!
    Attached Thumbnails Attached Thumbnails Schermafdruk van 2014-10-27 07:30:17.png
