Page 13 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 181 to 195 of 228
  1. #181
    Brendan chucks the whole rod. So some of the guys on the lake go buy the brand-new-used stuff from him
  2. #182
    Feb 2005
    Muskoka Canada
    The rods are the weak link. 141's won't make an f1 race, chatfields will make a few. 141's break parallel to the rod bolt (which is why people think the bolt failed, it was the rod) and chatfields fail almost exactly 1" below the wrist pin.
    For the most part it is the rev limiter that breaks the rods. Or you can just go buy some auto Verdi rods which last I heard have yet to have a failure.
    2023 TUFF 25
  3. #183
    We had one where the timing linkage broke allowing it to go full advance which added 12* at 8600 and it stuck broke a big omc rod. The small 5/16 rod bolts held strong
  4. #184
    Virginia Beach
    Quote Originally Posted by pyro View Post
    I have blue Aeroquip hose on everything except the 3 short pieces on the fuel rail and regulator, which I will also be changing out for the good stuff before I run it.
    What is that spaghetti nightmare? Wrong color wiring? Tystraps here and there? Fuel tank screwed to the floor with wood screws? Come on, Klien, a guy as persnickety as you, I didn't expect to see this mess.
    BTW...congratulations on your new addition.
    JWTjr.
  5. #185
    Sep 2002
    Now, you know those fuel tank screws are factory.
    the wiring isn't as clean as Greg's dash, I know.
    On a positive note, I found a Medalliin trim gauge with red markings to match the factory set. It will replace the Land & Sea jackplate indicator. I need to score a good manual 5" plate, or 4" with my 1" spacers.
  6. #186
    Quote Originally Posted by RBT View Post
    That blue aeroquip hose has a tendency to delaminate. Good stuff, but doesn't last forever.
    Rob, ypu don't need to change bolts. The sps and arp bolts don't break. Don't waste ypur money or other peoples. Spend money on things like magna fluxing. Ask Brendan power if he has EVER seen a rod bolt failure. Is he good enough?
  7. #187
    Quote Originally Posted by JWTjr. View Post
    JWTjr.
    Looks like my crap
    Sarasota, FL
    Yes I have much respect for Brendan Powers.
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  9. #189
    Sep 2002
    Rob, what do you recommend for high-pressure fuel hose? I thought Aeroquip was the cat's meow.
  10. #190
    Feb 2005
    Muskoka Canada
    Pyro that is a question I can't really answer. XRP makes a fuel line called hs-79, it so far has been perfect. BUT ypu better be sitiiimg down with four finger of Oban ( my fav) before you ask the price.
    2023 TUFF 25
  11. #191
    Sometimes peace of mind is worth some extra bucks, if it lasts 2-3 times longer.....
  12. #192
    Feb 2005
    Muskoka Canada
    True, but when you order fuel line ( and the the ends have to be installed at the factory ) and it cost 888 dollars, plus another 512 for two fuel filters ypu better have a TALL glass of scotch to help with the pain. And it BETTER last!
    2023 TUFF 25
  13. #193
    So thats not their version of "push lock" hose? Thought they had one?
  14. #194
    Feb 2005
    Muskoka Canada
    No. That would be way to easy
    2023 TUFF 25
  15. #195
    Sep 2002
    Forget that... I'll spend $50 every couple of years on the blue stuff, and I'll pour a three-finger Lagavulin 16 when the job is done.
    I use ethanol-free 90, if that counts for anything...
