Results 1 to 15 of 18
    Aug 2012
    Tenkiller Lake, OK
    300xs cylinder endoscope inspection
    I inspected my "good" 300xs with 13.4 hours on it after my other twin 300xs lost #5 piston and rod went thru the block. Does the spot in at the edge of the piston look like a chip in the piston? Note that due to the wide angle of the scope, the piston does not look round - it is the gray portion of the photos and the cylinder hatching is pronounced.
    Attached Thumbnails Attached Thumbnails 140927-102521.jpg   140927-102502.jpg   140927-104538.jpg
    Mar 2006
    Oklahoma City Ok.
    Not operating the borescope its hard for ME to really see what we are looking at BUT those pics look like cylinder bore (hatch) then headgasket if they use one. But in either case I see little hotspots with some piston splatter or something that is balling up in photo one. My 300xs only has about the same number of hours and hope I don't have the same luck. What did Mercury say about the one that blew, and what year of manufacture was it? Mine is 2013 sold in 2014. Roger
    Aug 2012
    Tenkiller Lake, OK
    Roger, What is posted is cylinder bore (hatch) then gap (which I think is the ring below the top of the piston) then piston (the gray splotched piece). Because of the extreme wide angle of the lense, it looks like the piston is curved the reverse direction that it is (round). So the "spot" at the edge is on the edge of the piston which looks like a piece is missing. Mercury doesn't let the servicing dealer open the motor. My tech thinks that " a small piece of aluminum" probably made a hot spot which either cause pre-ignition of detonation which lead to lunching the motor. My concern is that the "spot" is the genesis of a hot spot and then it's over! My motors are 2013's. Not also that Mercury has revised their break-in procedure for the replacement powerhead.
    May 2001
    great south bay
    What is the revision to the break in procedure?
    Aug 2012
    Tenkiller Lake, OK
    I checked the "new" furnished schedule with my Operations Manual schedule that came with my motors... No difference!
    Western Pennsylvania
    Any update on this?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Aug 2012
    Tenkiller Lake, OK
    I have about 30 hours on the motors. Both are now working well. I had to replace all the coils on the replacement powerhead due to a dead cylinder (port motor). They were reused from the broken powerhead. Mercury provided the new coils! I am still chasing being down 250 RPM's on the starboard motor. Maybe an intermittent coil issue there as well. only getting 6000 RPM on the starboard motor. I took this photo on December 27 - pretty good run!
Name:	12-2016 Garmin Speed.pdf
    Quote Originally Posted by Davidlake View Post
    Attachment 364407 "I'd say'
    From left to right in the pictures I see the bore, headgasket and cyl head. I dont see any of the piston? I do see what looks like a small void but the cameras sometimes show strange reflections etc.
    Aug 2012
    Tenkiller Lake, OK
    Thanks, After more research, I totally agree with your description of what is in the photos.
    If it runs good leave it alone. If it's slow fix it till its broke
  12. Likes NICE PAIR liked this post
  13. #12
    Feb 2016
    Bedford, NH
    I have the same issue with one motor down on RPM, same motor takes longer to spin up on plane. All the google searching is leading to a bad coil. Hopefully figure it out in the spring.
  14. #13
    Naples, Florida
    I don't see the piston in any of the pics. What it looks like to me is that you see the cylinder crosshatch. The lighter color is where the ring rides. The darker color is the cylinder wall above where the ring stoops at TDC. Next is the cast head. These motors don't have a gasket they use an oring. The area that looks goldish like a head gasket I believe is the machined squish are on the head that over hangs in the cylinder. I believe it's pretty fair to say that's not a chip in the edge of the sleeve as you can see that in one pic it looks like you can see one side of the "object" and another pic the other side. I'm very curious to see if is a piece of aluminum or a chunk of carbon. I highly doubt it and hope it's not part of the oring that came out of the groove during assembly and got crushed while torqueing the heads and now has become charred....
    Curiosity would definitely get the better of me and I'd be tearing that head off to see !!!!! It's only a total of 4 orings to replace.....
  15. #14
    Quote Originally Posted by Todd D View Post
    ^^^^ this ^^^^
  16. #15
    I removed my(2007 300xs) injectors and air injectors and sent out for cleaning due to what felt like a "vapor lock" for about 30 seconds on warm/hot restart. Going to start a new posting with cylinder pictures from Snap-On bore scope. Will try to get up over the weekend.
