Results 1 to 6 of 6
    Sep 2012
    Grandville, Michigan
    Fuel pressure Mercury Pro Max 225
    I have 35 psi fuel pressure on my 2000 Mercury Pro Max 225 at idle. Isn't this supposed to be 39 psi? Will 4 psi make a difference in power or top end rpm's? Everything is clean. All new filters. VST serviced. Injectors serviced. Could this be a bad regulator (weak spring inside regulator)?Thanks
    Melbourne, Florida
    or it could be your gauge, I would think it is OK, unless you are having issuses
    sw florida
    What is it with key on not running. ie no vacuum signal.
    Vacuum signal should pull it down a few.
    Dago
    Dec 2011
    Sunny Oregon
    At idle you have low manifold pressure ( high vacuum). It causes the regulator to drop fuel pressure to 35-36 because of the vacuum line attached to it from the manifold. At low vacuum like WOT and just plain not running the fuel pressure increases to 39.
    Sep 2012
    The fuel pressure is 35 psi with the key on, not running. After the pump stops running and I turn the key off it drops to 31 - 32 psi before holding. I am thinking the regulator has a weak spring (age). Any opinions?
    Mar 2011
    Virginia
    Early model Promaxes have 36-39# regulators. The later model (after serial number OG303xxx...1996 or newer) Promaxes usee a 35 +_1 regulator....you're probably fine.
    Go Time
    26 Regulator twin 250 EFI
