Results 61 to 75 of 340
09-21-2014, 12:31 PM #615000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
i might take that GS....
09-21-2014, 12:37 PM #62
250xb, 8" manual plate, 1.62 SM, tight-worked 30et copy, 1/4" over pad. Before someone says too high, etc... I ran 5/8" over with same prop when it had the 225. The boat did NOT BLOW OUT, it hooked while decelerating. Ran just under 100 very easily and I'm sure I would've raised it more had this not have happened and easily run over 100.... Not now!
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
09-21-2014, 12:39 PM #63
09-21-2014, 01:08 PM #645000 RPM
- Melbourne, Florida
- 645
- 13
for what it is worth, I have been running an Allison since the early 90's, when I used to play with top end runs I never found it beneficial to run with the prop shaft higher than the pad, I know some people do. My 2003 has been 105 with a 280, 2002 well above 100, like some others I have never hooked an Allison, in fact I have only been scared once, that being said I do not do any top end runs anymore, just to old I guess. Also I never felt the need to do anything to the pad, the man that designed it knows more than I do. I wish you luck, don't give up, remember any boat can bite you at any time.
09-21-2014, 01:12 PM #65
I've said it before, they all need to be respected.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-21-2014, 01:31 PM #66
Not nicked named a hooker for no reason just soon as ya give it to it never know the rucking your going to get in return just like a dirty old hooka loaded with std's and not a Stv
09-21-2014, 02:09 PM #67
Yep
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-21-2014, 03:11 PM #68
Your ET cope is also 15" correct? That lets you ru higher and stay hooked up.
21' Paramount
Mercury 300 Promax
09-21-2014, 03:12 PM #69
It's right at 14.875
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-21-2014, 03:30 PM #705000 RPM
- Jun 2007
- UTICA IL
- 576
If you cant chop the throttle something is wrong I can run 105 and chop it in mine any time and its a half inch under the pad....
09-21-2014, 03:32 PM #71
Is yours a 3.0?
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-21-2014, 03:37 PM #725000 RPM
- Jun 2007
- UTICA IL
- 576
No its a 20 inch 280 I wouldn't want a 3.0 on it...
09-21-2014, 03:38 PM #73
I see, we're talking 2 different things.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-21-2014, 03:45 PM #745000 RPM
- Jun 2007
- UTICA IL
- 576
I can tell you this the motor is to high and you need more seat time lots of it,thats all I will say...
09-21-2014, 03:47 PM #75
Im glad you have everything figured out for me. Thanks, have you had one with a non-ratcheting case?
2008 Mercury 300XS
91.7 - MPH
102 - MPH
