Results 1 to 11 of 11
09-11-2014, 05:30 AM #1Member
- Jun 2005
- 37
Another Merc to Johnson prop question
Trying to install a merc chopper on a Johnson. I know I can drill the front side of the splines out with a 1 inch whole saw until it hits the thrust washer. Once I do that it looks like I will have a lot of shaft showing were the prop nut goes. Will that be ok???
09-11-2014, 07:14 AM #2
There are two different castle nuts I have had , one is wider, and you can use a spacer or washers behind it. how far off are you from the cotter pin going through the castle nut?
Steve
09-11-2014, 04:36 PM #3
Use a splined spacer.
09-11-2014, 05:25 PM #4Member
- Jun 2005
- 37
So doesn't matter how much of the shaft is showing at the prop nut side and long as there spacer to lock the nut down?
09-11-2014, 05:45 PM #5
Use an omc or yamaha spline washer/spacer as said above.
Larry Gempp Jr.
09-11-2014, 05:49 PM #6
Sometimes I have 3/8+" showing. Never had a problem. There are also different sizes of thrust washers in front of the prop. I have a collection of both for different props.
09-12-2014, 08:01 AM #75000 RPM
- Jul 2005
- Baton Rouge, LA
- 723
- 25
For my buddies boat he uses a combination of OMC spacers and the Merc tab spacer depending on the prop and how much space there is.
09-12-2014, 01:13 PM #85000 RPM
- May 2004
- Washington, Missouri
- 329
You might have to mill off the weed cutters, I had to for my chopper.
09-12-2014, 05:15 PM #9Member
- Jun 2005
- 37
Thanks for the replies guys. Does anyone have a pic of a splined spacer? Are the weed cutters the 3 taps on the front of the prop and can I remove them myself with a cut off wheel?
09-12-2014, 07:44 PM #10
09-13-2014, 06:59 PM #11Member
- Jun 2005
- 37
Thank you sir. That what I thought they looked like. Just want to make sure I'm not missing anything.
