Results 1 to 15 of 15
09-09-2014, 09:00 PM #15000 RPM
- Sep 2012
- kentucky
- 199
225 Promax vacuum line portside vst help ...Please
The oil injection has been removed and I have studied all the Promax pics on the net of the vst vacuum line set up...but there is a small copper fitting with a small rubber boot on it with a pin coming out of the top that touches the bottom butterfly linkage that has two ports on it . It sets behind the vst and can't be seen in any pics I've found..So my question is where to route the top port to and bottom also...To say any help would be appreciated would be an understatement...Pics would be great either post them here or better yet send them to my phone 606 585 5917 thanks Shane
09-10-2014, 05:42 AM #2
Post pics to better help you!
09-10-2014, 06:23 AM #3
09-10-2014, 06:29 AM #481' HYDROSTREAM VECTOR / slightly Modified 200
09-10-2014, 06:37 AM #5
Went away when pump in vst showed up...........
09-10-2014, 06:42 AM #6
i think wired247 used one on his p max vst delete......im sure he'll be happy to explain routing and science behind it
09-10-2014, 06:44 AM #7
May not have enough "band width" for that..............
09-10-2014, 07:06 AM #8
It's a bleed shut off valve. Hooks to the intake and transfers fluid back to top of vst. Recirculation valve so to speak.
RockTeam Junk
09-10-2014, 08:29 AM #9
Tommy, just wanted to make sure exactly what he is referent too...You guys are hard on wired247....
09-10-2014, 08:52 AM #105000 RPM
- Sep 2012
- kentucky
- 199
Sorry guys I haven't set aside the time to post pics and vids but maybe that's a good thing I'd prolly aggravate the **** out of everyone posting alley pics and runs lol..But I'm kinda like woody harlson.." If its broke I can fix it... If its got hair on it I can ride it..If its got a beat..I can dance to it..but only if drunk of course.. But after further research on this blessed site..( shop time around here is $195 an hour and they will charge you that just to do a compression check..) but back to the story I was thinking about getting rid of the valve altogether but found out on here its the main reason you get a crisper hole shot on a laser injected system..it basically sucks up the fuel that gets pooled up under the reeds so to speak and routes it back into the system..so she's a keeper in my book and she will be there rigged in another fashion once I get rid of the vst ...By the way Jegs has those aeromotive regulators with a bleed line port and high pressure gauge..Thanks yall
09-10-2014, 09:04 AM #11
09-10-2014, 10:10 AM #1281' HYDROSTREAM VECTOR / slightly Modified 200
09-10-2014, 10:52 AM #135000 RPM
- Sep 2012
- kentucky
- 199
Thanks to everyone for the help up so to speak......I will guarantee y'all I'll return the favor or pass the knowledge on...Its good to belong to a site such as this whom we can combine and share all our knowledge...And it doesn't cost $195 an hour which basically includes brakes bull**** setup and coffee time and about 4 minutes actual labor...Thanks for you all and SNF
09-10-2014, 11:09 AM #14
09-10-2014, 12:33 PM #155000 RPM
- Sep 2012
- kentucky
- 199
Swoofe..lmao
