Results 1 to 5 of 5
    Aug 2014
    North Alabama
    Merc 25 Performance??
    Does anybody know of any modifications that can be made to a Mercury 25 2 stroke without pushing the limits and reliability too hard? im running 32 with it totally stock, i have a panther power trim unit with 5-11 inches of adjustable setback and a 18 pitch OEM mercury chopper on the way right now. im in the process of drilling out the foot as well.
    Pretty strong lil motor stock. I wouldn't think much more is to be had.
    Feb 2014
    Missouri
    Same as any ouut their. Carbs reeds porting pistons machining compression You can take it to the top hp cor that block size normally with parts as long as port times and size displacement stayed the same.
    Jan 2008
    eatonton ga
    U can block the idle reliefs to raise comp a little but thats about it better reeds maybee
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    97 xr 2001
    89 stv pro comp
    CURRENT RIDES
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    89 Stv pro comp
    Aug 2014
    North Alabama
    looks like im gonna get a adapter plate made for a bigger (35) carb, tune it down, and work my way up on it and see how it does. cant really do actual motor work on theese motors other than blueprinting.. how do i block the idle reliefs? are those the pinholes in the block ive heard about that you fill with epoxy or something similar?
