Results 1 to 15 of 15
    Nov 2012
    Wickford Rhode Island
    Superbuat/challenger I/o bilge blower
    Can any one give me an idea weather I should install a bilge blower on my super I/o , or just raise the hatch before starting. ??
    if so what kind and where to purchase ?
    Thanks !!!
    Argentine township, Mi.
    That's easy to answer. Get a blower that comes on before you can hit the key. Or wire a safety switch to your hatch? No bilge blower is a good way to blow up a boat.
    DaveW
    Nov 2012
    The old add age better safe than sorry ---thanks crazy horse.
    I think you can buy bilge blowers just about anyplace that sells boat stuff including Walmart? Most are 3in. or 4in dia. and use flex hose. It should have a timer setup that will not let you start the boat till it's done running.
    DaveW
    Jun 2010
    Rotorua New Zealand
    You might also consider setting the blower up to run for the period of time the engine is running and for a period of time after engine shutdown. Because the engines sit in a confined space there is a large build up of heat immediately post shutdown. With our diesels we set them up on timers to run the blowers for 15 mins after engines are shut down.
    Wellcraft Nova 230 XL, 300hp Johnson.
    Seahawk 45 Sport Fisher, twin 306hp Volvo.
    Steadcraft 28, Yanmar 300hp. Sold.
    Markline 800, Volvo 300hp. Sold.
    Haines Hunter V19, Volvo 170. Sold.
    16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
    FL / NY
    The best and safest is to do both. After shutting down I would also raise the hatch.
    Best to run all the time, keeps fresh air in the engine compartment all the time also reduces vapor lock.
    Nov 2012
    Ok!
    all appreciated
    the more the merrier !
    thx TUX the cover I bought from u this winter is the bom
    Jan 2007
    Amityville/Lindenhurst
    at one time your boat had it, it is a requirement and not having one is very dangerous.
    if the boat is insured and there is a claim relating to an engine fire or explosion it will be denied for not having the proper equipment- god willing no one gets hurt or killed
    http://www.uscgboating.org/assets/pdf/recalls/BSC69.pdf
    Nov 2012
    Thank you all -------
    I appreciate your input Rob F thanks !!!!!
    Nov 2012
    Will one be eenough or should I vent both port and starboard ?
  12. #12
    Jan 2007
    one side should be with a blower, one side should be left open, air in air out
    if you have 4 vents and want to do 2 blowers thats fine
  13. #13
    Jun 2010
    Rotorua New Zealand
    We usually use the blower for air extraction. So fresh air vented in at the front of the engine and vents at the rear with blowers to extract. This allows the fresh air to flow over the engine. We would set up with one for each engine.
  14. #14
    Jul 2008
    severn bridge
    blower should be on any time the motor is running and the boat is off plane! no blower working,no lock passage here!
  15. #15
    Nov 2012
    OK
    sounds like a plan .
    iam on it
    thanks again guys !!!!!
Mazco
