Results 1 to 15 of 47
Thread: 21' Eliminator Daytona w/ 300x
07-24-2014, 11:24 PM #1Member
- May 2013
- Yuma, AZ
- 43
Curious what would be the best prop for this combination... Boats a 1992 21' Eliminator Daytona with a 2001 300x on it, just bought the boat and it came with a 28p bravo 1 prop, seems a little small to me for that motor... Any suggestions on the best prop and what kind of speeds can be achieved, thanks
07-24-2014, 11:58 PM #2
Does it look like this?
My 21 really liked a BBlades Blaster 30. That was with a 300XS, 1.75 gears. 105 mph Great all around prop.
Have fun.
07-25-2014, 01:09 AM #3Member
- May 2013
- Yuma, AZ
- 43
07-25-2014, 01:19 AM #4Member
- May 2013
- Yuma, AZ
- 43
What remains was that???... 105 seems a little much with 1.75 gears factoring prop slip
07-25-2014, 09:06 AM #5
Sorry, It was 1.62 drive ratio, 300XS offshore
07-25-2014, 09:33 AM #6Member
- May 2013
- Yuma, AZ
- 43
What rpm were you spinning?
07-25-2014, 06:23 PM #7
07-26-2014, 01:19 AM #8
Try the BBlades Blaster. You wont regret it.
08-07-2014, 09:05 AM #9Member
- May 2013
- Yuma, AZ
- 43
Update, tried a 28p offshore cut yesterday...111 deg outside, perfectly flat water, spun it to 6700, left tank full of fuel, right tank about half...got 99mph...had the jack plate ran all the way up, got a descent amount of trim into it but could feel it get "over trimmed"...im thinking in should move the motor up a mounting hole or two on the jack plate itself, still had 25lbs of water pressure at this setup
08-07-2014, 07:30 PM #10Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,606
- 600
- 901
- 1679
- 7085
- 3 Post(s)
Blaster or a drag four. Randy (Wildman) rigs his 21s with new xs motors and his last 3 have been 105 to 108.
08-10-2014, 07:40 PM #11
08-28-2015, 01:45 PM #12Member
- May 2013
- Yuma, AZ
- 43
Wow been awhile since I've been on here ...just a little update, I tried a buddies 32p 3 blade cleaver and got it to 112, it was on the limiter at 6800...can't wait to try a 34p, really leaning towards the BBlades blaster, nice looking prop
08-28-2015, 05:20 PM #13
Hello ,if your at 112 on limiter with 32 cleaver than that's the prop especially when you add a passenger .
08-31-2015, 10:38 PM #14
Pics please ????
FINAL TOUCH DETAILING
08-31-2015, 11:06 PM #15Supporting Member
- Apr 2003
- 6,606
- 600
- 901
- 1679
- 7085
- 3 Post(s)
A 32 drag 4 that has been trued will be your best all around prop with a running height of 1 1/4 above the pad (assuming you don't have a bunch of setback). Was the 112 gps? that sounds like a pretty tall order for that hull and the heat you run in. Glad to hear you are having fun with it.
