Results 1 to 10 of 10
Thread: ProMax vs 260 injectors...
07-22-2014, 09:28 PM #1
Wondering what is the difference performance-wise between the pink tipped Keihin injectors from a ProMax and the Bosch injectors from a 260/280/drag? I'm thinking about doing a project engine, possibly using a more-than-moderately ported ProMax block with a laser injected front with SVS intake. All driven with drag electrics. I guess my main concern is if the Keihin injectors are capable of providing the fuel for it? I would imagine that they are plenty, but want to run it by you guys before doing it. I'm sure it's been done before.
07-23-2014, 07:42 AM #2
Yes the Keihn injectors will handle mods up to 280 HP increase. The best combination is get a NON progressive intake to replace the Progressive intake you most likely currently have. The NON progressive works much better with the SVS. Also trash the VST and go with a Bosh 984 pump and adjustable fuel regulator.
07-23-2014, 07:55 AM #3
VST won't be an issue. I haven't run a VST on even a stock ProMax in several years. Prefer to go straight to the 260 style fuel system.
Bud, are you talking about the Keihins will handle "up to" 280hp, or "an additional 280hp"? I'm sure you mean the former, but I want to be sure. To be even clearer...does anyone know the max hp that the Keihins will handle in a 2.5 Merc?
07-23-2014, 08:08 AM #4
With drag electronics your fuel pressure will be about 50 psi. Start there. I love my PM set up.
XR2001 & XB2002
07-23-2014, 09:19 AM #5Bud Conner "Heathen" "Defending Our Constitution"
07-23-2014, 10:58 AM #6
if i was still using a mercury ecu
these are the ones i would buy!
http://www.fiveomotorsport.com/obd1-...es-450-550-650Last edited by PanRonnie; 07-23-2014 at 11:02 AM.
07-23-2014, 01:50 PM #7
Is the progressive intake not in the linkage itself? You're referring to the way the bottom butterfly's open before the top ones correct?
1992 STV River Rocket - bottle fed 260
07-23-2014, 01:52 PM #8
Yes its all in the linkage that makes a NON progressive different than a Progressive. The throttle bodies are basically the same.
07-23-2014, 02:05 PM #9Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
i believe they only came on the first 220 laser motas it not to difficult to modify the other linkage
07-24-2014, 03:51 PM #10
Those injectors will work fine Paul. Weve been running them on our v6 comp motors for yrs on 56 lbs
