Results 1 to 8 of 8
07-08-2014, 09:56 PM #1
Need thrust washer to run SRX on a Merc
Anybody got one laying around they don't need?
If not, How about a part number so I can search for one.
Thanks
07-08-2014, 10:17 PM #2
Try this
1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
07-09-2014, 06:52 PM #3
Thanks
07-09-2014, 09:10 PM #4
Dave, I have one! No longer use it
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-10-2014, 06:49 PM #5Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
What is the purpose of the plastic washer that DAH sell with the thrust washer. I dropped mine in the lake...
It's been 2 years since I've run my SRX and when I went to put it on, I thought (a) what is this for and then (b) oops
07-10-2014, 07:34 PM #6
The other things you'll need are a thin aft washer, and a half-thickness nylock nut. There won't be enough propshaft sticking out to engage the nylon with a regular prop nut. DAH has these hard-to-find prop nuts.
07-11-2014, 09:07 PM #7Team Member
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
OK, so the thin plastic washer I dropped in the lake goes on the aft end of the prop shaft?
07-11-2014, 09:27 PM #8
I run the thrust washer pictured in my previous post and a std flat washer with a cut down merc nylock nut. You can take a std nut and turn it down to about 5/8 of the original depth and be ok given it is torqued properly and the nut is fresh. I ran a 27 SRX at 3 lakes this way an entire weekend and checked the nut torque before we headed home and it hadn't changed. I was a little wigged out by not using a traditional lock tab setup but it worked fine for me.
David, I'm not familiar with the washer you are referring to but if it resembles a flat washer in any way, the yes, it most likely lives directly behind the prop nut.1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
