Results 61 to 75 of 92
07-18-2014, 07:09 PM #61
Im not a believer in that a GS would be a slouch in the acceleration dept with a 250xb, they have plenty of torque to get a sub #1,000 hull moving.
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
07-18-2014, 09:59 PM #62
Weight makes all the difference with acceleration. Weight and motor being equal these boats will run with any of them in a 1/4. Surprised a bunch of guys in mine.
2006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
07-18-2014, 10:06 PM #63
I'm sure you have nothing wrong with drag racing, ive done my share of it with cars and bikes. Thats not really a concern with me regarding boats, im just a recreational boater that's always trying to better MY last speed. Thats my race
2008 Mercury 300XS
91.7 - MPH
102 - MPH
07-19-2014, 05:35 AM #64
Acceleration is good....hence the name.
Bob"have you met my little fly named scream?"
GSE #1 2004 GSE, 2004 225X Promax... RIP
GSE #2 2013, Gen2 200XS ROS
07-19-2014, 04:55 PM #65Team Member
- Feb 2003
- Punta Gorda, FL
- 658
- 17
- 79
Ziemer can really drive that Allison in a 1/4 mile or top end. It is not as easy as he makes it look. I had to have an STV with training wheels
to keep up with him. Daddy "Z"
07-20-2014, 02:18 PM #66Member
- May 2014
- Illinois
- 65
I read about people doing an Allison-cut skeg... where on the skeg is the 'cut' and what is the theory behind this?
07-20-2014, 02:42 PM #67
Its a swept skeg a little more cutting the leading edge back more. Or more swept back is the out come. Though most guys say now the SM can be left stock with no problem. The Allison mod for a skeg goes way back in years. I cant remember at what speed the stock SM is capable off on an Allison but theres guys that can chime in that go 110+ that would know that answer. lighter hulls and faster boat guys try many things for safety and just experimenting seeing what works and what doesn't.
07-20-2014, 07:58 PM #68
On a GS, no need to do a allison cut skeg.
2001 Allison XB2003
2006 Mercury 250XS
Go Daddy Go! Racing
07-20-2014, 09:39 PM #698000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
As far as mpg I can run my gs all day on 20-25 gallons of gas I even have a 280 get good mpg as long as it's not on the rev limiter I am actually pulling mine out of mouth balls in the next two weeks
07-21-2014, 12:06 AM #70
There are two major mistakes people make when letting off after a high speed run.
Number one is, they a have over trimmed and chop the throttle which turns in to an instant bow steer situation. In this instance it's best to bump the trim down first then get out of the throttle.
The number two mistake is to chop the throttle and jerk the wheel to the right which is a natural reaction since the steering wheel will want to turn to the left as the torque is released from the prop. The thing to do is to actually steer to the left slightly at the same time you drop the throttle. Once the boat makes that initial move, you can steer it anywhere you want. Once you learn this move, dropping the throttle on any 20' Allison is no problem.
On a side note, the 21' bass boats are the only Allison's that I will adjust a hydroulic plate while running at high speed and it is also the only model that I will lower the jack plate as I am coming out of the throttle.Lee Sanderson
07-22-2014, 05:15 PM #71Team Member
- Feb 2003
- Punta Gorda, FL
- 658
- 17
- 79
I agree trim down gradually and then come off throttle gently. It works even in an STV.
07-22-2014, 06:27 PM #72Member
- May 2014
- Illinois
- 65
Any thoughts on running 3-blade versus 4-blade props on the GS? Is handling any different, or is it more a factor of the blade shape?
08-01-2014, 07:08 AM #73
Slight increase yesterday, ran 95 flat. As some have stated, I think a 225 could get very close to 100 in good air, more setback, higher rev limiter, etc... I have my eye out for a clean 3.0 if anyone knows of one? Could be a 250xb, 300pm or 300x. Also, this 2000 Promax will be listed soon, less than 100 hrs on Jay Smith rebuild, top pinned pistons, small shaft Sportmaster, stock ecu. Thanks
2008 Mercury 300XS
91.7 - MPH
102 - MPH
08-01-2014, 08:56 AM #74
hp
Sean, that's what you need, a motor that will get you triple digits every time out like your little viper. You know you will not be happy until you have that. (hard to be happy with a slower boat) I'm sure you could get your gs close to 100 with the 225 but it would have to be perfect weather, prop, setback, weight, wind, tide etc...now if that ally just drove on a string like the viper.....
1990 Viper 140 crossflow
2011 Sea Hunt 232 Ultra
1995 Laser 380
1984 Reaction 19 project.........
08-01-2014, 09:21 AM #75
I agree. I'm getting a bit more use to the Allison. It definitely requires port side weight, I forgot to put it in yesterday and it was quite a handful! The 2 boats feel alot different, no doubt.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
