Results 16 to 30 of 31
Thread: Fountain 29' CC motor question
08-10-2014, 10:38 AM #16Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Sundance,
sent you an email/ pm from the THT site.
Bolted up motors yesterday, they're hitting the swim platform before they hit the stops on motor.
Wondering about correct engine height and best prop options
08-10-2014, 10:14 PM #17Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
08-11-2014, 09:57 AM #18
08-11-2014, 10:05 AM #19
What are the center to center measurement? They look far apart to me....
True Viking
Scarab 34 SS with Triple OMC 4.0 V8's
08-11-2014, 11:06 AM #20Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Didn't hook up steering yet. The rams came with the motors, I think they're seastar. In a box in my van, I'll check again later.
08-11-2014, 11:11 AM #21Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
That pic might be a little deceiving, they're closer together than it looks. I'll try to post a pic of the back of the boat. Not sure of center to center measurement, I'll try to get back to the boat this afternoon.
08-11-2014, 11:21 AM #22Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
08-11-2014, 11:21 AM #235000 RPM
- Jul 2004
- Ft. Lauderdale, FL
- 105
If Sea Star rams, install spacers on the shaft to limit hard over turning. They look like they're on 26" centers, which if you went narrower, you would need spacers either way to keep the inside of the cowlings from hitting hard over, so either way need some spacers...
Sundance Marine
08-11-2014, 11:56 AM #24Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Might have to replace the motor mounts.
Thoughts on solid mounts or stock rubber mounts ?
11-23-2014, 09:16 PM #25Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Finally got the boat in last Thursday for some testing.
Got out the boat up to 32-3400 when stbd motor started crappin out.
Boat was doing 47mph.
Waiting for mech to change high pressure fuel pump.
Can't wait to see what it will do at 6000rpm
11-23-2014, 09:24 PM #26
11-24-2014, 06:48 AM #27Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Baja, did the vst & all the filters already. Mech thinks it's the high pressure fuel pump.
I have a spare kicking around, were gonna swap it out and see what happens. This motor was doing the same thing when I bought it. I thought going through the vst and changing all the filters would have fixed the issue ?
We'll see if swapping out the pump will do the trick.
11-24-2014, 07:25 AM #28Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Before you swap parts, get a fuel pressure gauge on it to see what the pressure actually is.
12-18-2014, 11:08 PM #29Junior Member
- Jun 2008
- Jamaica Bay, NY
- 21
Swapped out the high pressure pump, no improvement.
Changed the 2 low pressure fuel pumps yesterday, seems to have fixed the issue.
Dropped it in yesterday to test it out, stbd motor runs fine but now the port motor doesn't want to turn over 4500rpm.
Ran nice at 43-4400rpms, 57.5 mph. With Mach Sterndriver 4blade 14.5x26
12-19-2014, 08:29 AM #30
