![Thanks](https://www.screamandfly.com/dbtech/thanks/images/thanks.png)
![Likes](https://www.screamandfly.com/dbtech/thanks/images/likes.png)
Results 1 to 10 of 10
06-27-2014, 11:39 AM #1
5000 RPM
- Sep 2005
- fort lauderedale
- 163
sst 60 powerhead low recreational hours complete less carbs
Complete sst 60 powerhead currently mounted on recreational 20 inch midsection..I had this motor on my wahoo 16 and it would pull 6000 plus with a 19 sst I sold the boat and a few others i had,,, put my 175 on my 16 magnum,instead of the 3 cyl. and decided to sell the sst 60 to someone who will use it . this motor has the factory ignition system with the power pack rev limiter punched out by the factory and that little gray epoxy spot over thit, it has original cyl head block all of it except for the carbs complete drop on less carbs!!..the use for racing only decal is on the exh side water jacket this IS an sst 60....if you had a late model 3 cyl and were rebuilding it and needed a powerhead from a rebuilder you could buy this put on your carbs and run..or maybe you race sst 60 and need a p/head
would sell for $1850.00 or
WILD CARD would trade even for 2007 or later clean low milage BUELL BLAST 500 ccmotorcycle because thats where the $$ are heading after selling this sst 60... IF a service customer came in I could get this price for a complete p/head swap, but would like this to go to a s&f speed junky
joel
9547637729
07-01-2014, 02:14 PM #2
Member
- Sep 2010
- Carrollton, Ohio
- 33
Joel,
Do you have any more pictures? I am interested but not that informed about the differences between an SST 60 and stock 3 cylinder. Thanks.
Fritz
07-01-2014, 03:13 PM #3
5000 RPM
- Jan 2008
- redding cal
- 114
what crank is in engine, ? fish motor cranks have fine spline. long shaft motors standard with fine spline. thanks greg
07-01-2014, 03:44 PM #4
Member
- Sep 2010
- Carrollton, Ohio
- 33
It is a 4 spline. I was thinking about the power-head for a Stinger that I am building, primarily from NOS parts. I pretty much have everything including the lower unit and standard 15" OMC midsection. I have a power head from a 1975 Evinrude Hustler, but it doesn't have high compression head or anything else special done to it. I am not planning on racing, just want a bit higher performance setup. Thanks, Fritz
07-01-2014, 04:37 PM #5
New Member
- Jul 2014
- Canada
Do you have any pictures of what you have ..thank Katorian
07-01-2014, 06:30 PM #6
Member
- Sep 2010
- Carrollton, Ohio
- 33
07-01-2014, 06:40 PM #7
Scribed. Gary
07-02-2014, 02:14 PM #8
5000 RPM
- Jan 2008
- redding cal
- 114
you have most of a sst60. is lower unit sst 60? and how much for lu. thanks greg
06-10-2015, 11:45 AM #9
New Member
- Jun 2015
- sarasota
Seeing if you still have the sst 60 powerhead?
06-27-2015, 10:23 PM #10
New Member
- Jun 2015
- Maryland
Am interested; please call me at 301-481-9175.
Thanks!
