Results 1 to 3 of 3
    Mar 2010
    netherlands
    Casale toploader gear lash
    I just rebuilt my ole casale toploader with fresh bearings and seals. Im about to set the gear lash at 0.008- 0.010, measured on the top gear. Now i read in a topic the lash was measured on the out shaft key. I assume it should be set at the gear?
    Thanx,
    Frank
    Oke, i figured it out..runs smooth.
    Jan 2006
    macon GA
    Look up Ron Brocksma....not sure spelling is right on last name.
    He is the man on those v-drives.
    Northern ILL.
    JJ BEAVERFAB http://beaverfab.com/6101.html
    He makes about everything for the V-drive gearbox
    UMPBA 926 Gas Jet
