Results 1 to 9 of 9
    Aug 2011
    225 Promax Rev limter options.
    My stock/original 1997 2.5 225 promax pulls a 32 ET with 1.75 gears hard to the limiter at 103 MPH every time out.
    If I wanted more speed I'd either have to have this prop pitched up, buy a 34" cleaver or similar or raise my limiter.
    Besides Brucato (which isn't in the budget right now) are there any decent ways to bring the limiter up to 7k or so?
    1986 Hydrostream Valero YT - Fully restored '12.
    1997 225 Promax.
    TX......somewhere?
    If I had a "plain jane" ole pm doing that, I wouldn't touch it! Get a bigger prop..............
    Windsor, Ontario
    do you still have oil injection? you could delete it and the rev limiter and call it good
    Aug 2011
    Oil injection is removed as are the "black boxes" for idle stabilization and timing retarding both for simplicity and reliability. I didn't know you can unplug the limiter... How is that done?
    1997 225 Promax.
    Dec 2011
    Sunny Oregon
    You cannot unplug the limiter as its built into the ECU's program. You can send it in to the get the limiter raised. Not cheap though.
    Jun 2011
    South FL
    Might want to get a lightweight flywheel if you're raising the limiter.
    1989 24ft Skater, Twin Diamond Marine 280's with Diamond Tuners, 34p Cleavers. A few pieces of JL Audio equipment.
    1988 18ft Talon- SOLD
    Aug 2011
    Quote Originally Posted by tony97gt View Post
    Oh nevermind then - this thing runs to well to monkey with it. Maybe I'll just have the prop tweaked.
    thanks for the info.
    1997 225 Promax.
    TX......somewhere?
    Quote Originally Posted by Fullthrottleguy View Post
    Good for you!
    FL / NY
    Smart move!
