Results 1 to 5 of 5
    Jan 2011
    Saint Matthews, S.C
    took checkmate for test run today-results-
    Took my 1977 16'2 checkmate trimate for a test drive today. Stock 1980 85 johnson 5 inch setback cavitation plate bout 1.5 above bottom turning a 13 1/2 x 24 raker at 5300 5400 rpms at 51 52 mph wit me, cooler,tools box,battery and 12gallons of gas. I was impressed on how good it rode believe if i lower motor lil bit more i can pick up a couple more mph
    1980 13ft critchfeild
    2001 14ft bug buster 30 yamaha
    1977 checkmate trimat
    1976 glassmaster vhull
    Jan 2005
    Georgia
    Why would you gain speed by lowering? I would check to see what that engine will turn and either work on your height or prop to get the most.
    btw, 52 is pretty good I'd think but do still question the rpms.
    You never know what your faith is, until your faith has been truly tested.
    Dec 2008
    79st,Eliot,fl keys,world wide action Ryder yeah hoe
    Engine doesn't seem to b slipping with that small rpm I have a 15 whaler with 115 omc n a 22 raker &@6500 I'm at 63 mph on gps I'm yet to try the 24 raker cuz it accelerates so hard with the 22
    Jan 2011
    Saint Matthews, S.C
    Quote Originally Posted by Stoker1 View Post
    Reason i mentioned lowering the motor is because once u get bout half trim the prop starts slipping
    Jan 2011
    Saint Matthews, S.C
    Quote Originally Posted by Mr. Action View Post
    Yes it starts slipping at bout half trim. I guess the rpm gauge is right. It has 2,4,6,H adjustments on the back i have set to six cause wen u set it on four its way off cause theres no way im im turning three thousand rpm on plain
