Page 7 of 69 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 57 ... LastLast
Results 91 to 105 of 1025
  1. #91
    Nov 2013
    Kissimmee FL
ID:	314842Click image for larger version.
ID:	314843Click image for larger version.
ID:	314844Click image for larger version.
    The core is all covered!
    The whole boat bottom shell is covered with DB1700 to seal the core.
    Will start on the stringer lay out and front bulk head tomorrow.
  2. #92
    Nov 2003
    Looks great, nice work!!
  3. #93
    Nov 2013
    Kissimmee FL
ID:	315065Click image for larger version.
ID:	315066Click image for larger version.
    Got the center stringer set and the front bulk head. have the cap for the stringer cut and some of the side stringers.
    This thing is KICKING this old mans but.
    In and out, In and out, In and out.
    Hope to have this all set by this weekend. Then set the floor in next.
  4. #94
    Nov 2009
    Jax, Fl.
    Just think how young you will feel laying down some fast passes in rock solid rig that you did your self. Hard parts all but done. Keep up the good work.
  5. #95
    Nov 2013
    Kissimmee FL
    That's what has kept me going for almost a year now.
    I am only building the boat so I have some thing to hang the eng on.
    When the boat is done I will post the eng build up on this thread also.
    Starting with a 240 Sport Jet block. Have the liners pulled now to do the port and timing work.
    Have a 7 petal carb intake for it.
    Can not wait that's when the fun part starts for me.
  6. #96
    Dec 2014
    Kissimmee Florida
    great Job david ;-)
    Twister 25 Ft Race Catamaran - Mercury 300XS
  7. #97
    Doing a nice job on the rebuild. Should last forever. That 1st ride will make you smile for days......The stupid part of me wants to do another rebuild, but the old man pains I get from a hard days work bending over working on a hull or glassing on a deck tell me I really shouldn't.
  8. #98
    Nov 2013
    Kissimmee FL
ID:	315190Click image for larger version.
ID:	315189Click image for larger version.
ID:	315188Click image for larger version.
ID:	315191Click image for larger version.
ID:	315192Baby has back now.....................
    Have all the stringer pieces cut and the floor. Also have the front box section cuts done.
    Have 3" riser to rest my feet on just like the original.
    Will have lots of lay up to do this weekend. Will see how much I can get done before I yell UNCEL...........................
  9. #99
    Crown/St.Fancis, Minnesota
    Looks great! I say throw an extra small bulkhead up in the bow and forget the airbox but thats just me cause I would toss stuff up under there like life jackets and stuff and it will keep em from sliding out plus more foot/leg room. Then again I am 6' 2" so I will take all the leg room I can get. Looks awesome though. Cant wait to see it all done.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
  10. #100
    Nov 2013
    Kissimmee FL
ID:	315280Click image for larger version.
ID:	315281Got all the bulkheads laid up and center stringer box in.
    Will clean it up and drill two holes from the side sections in to the center box section for water drains.
    I have a 1" hole in the back of the center section for a drain plug. There will also be a hole drilled in to the front bulkhead to drain the front box section.
    When the plug is in it will make this all flotation.
    Getting close to setting the top on to fit the last parts.
    I will set two side brace that will tie into the transom and the box sections built in to the splash well. Thy will be L shaped and form a set box with a cross piece at the front.
    The 16 gal fuel tanks one on each side and the batt in the middle in front of the center knee braces.
    Well time to set the floor. hate to cover up all this work. LOL
  11. #101
    Nov 2013
    Kissimmee FL
ID:	315282DAM this old man is strong.............................
  12. #102
    Nov 2013
    Kissimmee FL
ID:	315290Click image for larger version.
ID:	315291Click image for larger version.
ID:	315292Click image for larger version.
    Drain holes added and floor set.
  13. #103
    Nov 2013
    Kissimmee FL
    I have bin doing some measuring now that the floor is set.
    I have ordered two blank 10 gal fuel cells in opaque so I can see the fuel level.
    I will put one at each side of the boat in the wing sections.
    I have orders the fuel pump Carter P4389.
    I have a Racor 120R-RAC-01 fuel filter that I will use.
    the filter has two inputs so I will hook up one line from each tank to the filter.
    Also got a bypass regulator to put after the pump and T off the return to each tank.
    Each tank will get a remote fill cap to the top side.
    I am thinking of using Optima 6V 800 CCA batt. one on each side. The combined weight is about the same as one 12V Optima 800 CCA.
  14. #104
    Aug 2012
    beaumont, tx
    Center steer? Side steer?
  15. #105
    Nov 2013
    Kissimmee FL
    Center steer all the way. with a removable bench in the back.
