Page 68 of 69 FirstFirst ... 18 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 LastLast
Results 1,006 to 1,020 of 1025
  1. #1006
    Aug 2012
    beaumont, tx
    Quote Originally Posted by 90 5.0 View Post
    Perhaps the reason some responses come the way they do is because of the attitude you pop off with at times.
    this^^^^ and the Professor like attitude came quickly after 2 2.5 builds that lasted 2 secs and a boat you dont drive.........
  2. #1007
    Nov 2013
    Kissimmee FL
    Well if you are going to talk **** lets get it right. 1 2.5 build (don't forget never even seen one before this build)and it lasted 3 mouths of hard beating and I do drive it just not very good yet.
    So now that we have that strait.
ID:	393846Here are the rod slots roughed out.
  3. #1008
    Quote Originally Posted by dwilfong View Post
    You know what after being beat up so much you just don't F#KING give a ****........................
    Wonder why those that truly know don't bother coming on here any more?????????
    I don't but hay you know I don't F#CKING GIVE A **** SO THERE...................................
    FU@KING COMP VECTOR YA WHAT EVER>>>>>>>>>>>>>>>>>>>>>>>>>
    350lbs turd with no core and just a few wood stringers...............................................
    Well my **** is 460lbs and has the full Monty done to it...................
    You know you get tired of all the BS that just seam to grow with time.
    Done with all the nicety you all want to start talking BS I will call you on it.....................
    Done with all the parrot talking.
    Hey Fong , all kiddin aside dude ... >
  4. #1009
    Nov 2013
    Kissimmee FL
    Tried it after the heart attack did not do **** but make me feel like ****.
    That is for girls that can't handle there period.
    This is what real wackos take.
    I'm on a mission from Good now. Click image for larger version.
    Don't piss me off any more.
    You think you seen stupid from me?????????
    Think again!!!!!!!!!!!!!!!!!!
  5. #1010
    Oct 2017
    Hugo, MN
    Pure. Comedy. Lives. Here.
  6. Likes dwilfong, XstreamVking liked this post
  7. #1011
    Nov 2013
    Kissimmee FL
    OK got two pistons all finished up. polished all the cuts to remove any stress risers.
  8. Likes Slimm, Tom Foley liked this post
  9. #1012
    Nov 2013
    Kissimmee FL
  10. Likes Slimm liked this post
  11. #1013
    Nov 2013
    Kissimmee FL
ID:	395034final weight of the rotating assembly.
  12. Likes Scream And Fly liked this post
  13. #1014
    Nov 2013
    Kissimmee FL
ID:	395208getting close now Ed is cutting the chest will have it back tomorrow to finish up the port work.
  14. Likes Slimm, Scream And Fly liked this post
  15. #1015
    Nov 2013
    Kissimmee FL
  16. Likes Scream And Fly, Slimm liked this post
  17. #1016
    Shreveport, La.
    About the picture in post 1007 I`m wondering if you cut the bottom of the sleeve completely out or did you leave a small part to help keep the integrity of the sleeve? Seems like if you cut it out the roundness at the bottom will change and maybe squeeze the piston.
  18. #1017
    Nov 2013
    Kissimmee FL
    Quote Originally Posted by Da Bull View Post
    Did not cut any thing on the bottom of the what I call the register in the block.
    The walls between the boost and finger do not go all the way to the bottom as cast.
    Just cut the slot in the bottom of the cylinder to unblock the flow to the small ports.
    As far as the steel sleeve its self the bottom windows just need to be raised. The width is close to what is needed.
  19. #1018
    Nov 2013
    Kissimmee FL
  20. Likes W2F a V-King, Slimm liked this post
  21. #1019
    Nov 2013
    Kissimmee FL
Name:	2nd block build up.jpg
ID:	396344Click image for larger version.
Name:	rotating assy 2nd eng build up.jpg
ID:	396345OK happy birthday to me...........LOL
    Time to assemble the new engine.
    Total cost of the new block is $800 ready to assemble.
    $400 for two new pistons and $167 for one rod.
    The worst part was 1 new sport jet reed block $170 for that bugger.
    1 new rod bearing set $50 and 2 new intake gaskets $25
    Need less to say I will make sure the dam thing is not to lean the next time I spool it up............LOL
    Not relay to broke up over it all needed a reason to try a new port map any way.
    That and I love to build engines.
    The boat is just some thing to hang a eng on to me.
  22. #1020
    Feb 2005
    Toronto Canada
    you should dyno it
    RIP RPM RACING
    RIP Galen Burden
    2011 ODBA PRO DRAG world Champions
    Triad River Rocket
