2006 24 Predator (24 Skater copy) BOAT IS SOLD
Per Predator website, boat is composite (Diviny-cell, core-cell foam, and Penske Extreme Composites).
2 45 gallon fuel tanks; no tank issues which plague the Skaters. Marine Machine steering, Capilano helm, Bob’s Extreme jackplate (this is the heavy duty one). Fusion head unit with 2 Rockford Fosgate 6 ½’s. All Livorsi gauges including GPS speedo with tattletale. 2 covers: 1 full cover and 1 cockpit cover. Engine cowl cover. Boat is in good condition, but not perfect. Has some chips on the side, but they’re pretty small. The clear on the front deck seems to be coming off in some spots, but you really can’t tell unless your right up next to it. Interior is in good shape (no rips/tears). This hull was designed for a single engine and has a water diverter to give the lower unit some shelter when running.
Single 300X. Motor has under 200 hours. Sportmaster 1.62 lower (fat shaft) with vent kit installed by Mike Anderson at Performance Outboard and Machine. Mike Nass cowl and skirt. MAD EFI 4 seal billet carrier kit. READ THIS: motor currently has #6 piston detonated. Block is fine and every other piston seems to be fine. This occurred because of low octane fuel. To get running again you can either bore it and put a new larger piston in OR put a new factory sleeve and piston in. Also needs a head on the side which detonation occurred. If no one wants it as is, I’m going to fix it and sell a running boat.
Double torsion axle trailer. This is a really nice trailer. Welded aluminum bunks. Has brakes, but never used and can’t confirm if they work. Tires have lots of tread on them.
25k as is
30k fixed
I'll try to get some interior pics up soon.
(727) 515-3402
Brian
Boat is sold. Got a deposit.
