Results 46 to 58 of 58
02-16-2016, 07:57 PM #46
Very nice!!!!!!
MO
02-16-2016, 10:20 PM #47Junior Member
- Dec 2014
- Northeast
Great looking boat.
02-17-2016, 05:14 PM #48
Great looking boat!
08-22-2016, 01:25 PM #49Junior Member
- Aug 2010
- Buna, TX.
- 10
2016 boat
Errol builds a nice boat. Found a couple of small oversights or maybe just my nit picky preferences. Still tweaking props, boat balance, etc. A 632 pound Verado on the transom and 75 gallons of fuel makes it sit low in the back and isn't conducive to high mph. Light load of fuel and the wrong prop runs 72.8 GPS. I run offshore a lot. Looking at a hydromotive 5 blade to minimize aeration in big chop and up to 3-5 seas. It likes a lot higher X height and more transom lift than the Turbo TXP OT-4 can deliver. It eats big chop comfortably and with a little throttle control takes 3-5 following seas bone dry. Overall pleased with the boat!
08-22-2016, 01:43 PM #50
Glad you like your boat. I also am happy with mine. As with any boat, it takes time to get them dialed in. I have used mine in some larger tourneys (BASS-Open; FLW-Costa) and never doubted the boat- just my hookset.....LOL. Welcome to the Lanier boats!
08-22-2016, 02:19 PM #51Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
Take Brent up on his offer to help you with set up. He and Mike have done everything you can do in one-not all good stuff but they know how to take it to the limits for sure....
08-22-2016, 02:45 PM #52
08-22-2016, 03:02 PM #53Junior Member
- Aug 2010
- Buna, TX.
- 10
I'll take any help/advice offered! $$$
08-22-2016, 03:26 PM #54Supporting Member
- Apr 2003
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
08-23-2016, 08:49 PM #55Junior Member
- Aug 2010
- Buna, TX.
- 10
A little history of my old boat... 275 Verado 630 pounds, 1.85 gears. Two props TXP (3 blade long full size tube) and TXP OT4 (4 blade short undersize tube), both props 26 pitch.
The TXP 3 shoved my Stratus 201 XL Pro 80 mph at 6200 rpm's with a tournament load and two adults. Put a TXP OT4 on the Stratus and the RPM's dropped 5900 rpms and it slowed down to 75 WFO. The dealer that put the boat together got 83 out of it with enough gas to get back to the boat ramp and no load.
Rev limiter on the Verado is 6400 RPM's.
____________________
Now to my LCB... Standard weight hull, 275 Verado, Bobs Extreme jack plate, 75 gallons fuel capacity, poling platform, 4G radar and fishing lights on the platform. Equates to - LOT's of stern weight!
Errol got 72 GPS out if my LCB with about 10 gallons of gas by himself in the boat with the 4 blade prop. He predicted mid 70's out of the boat while he was building it.
___________________
My LCB loaded with +/- 50 gallons of fuel, two adults and tested under similar water conditions -
The three blade SUCKS on the LCB. It aerates WAY too much coming up on plane and in sizable chop and is a almost impossible to prevent it from blowing out in the bigger stuff offshore when trying to keep it on plane. On top end after tweaking trim and jack plate to optimum at speed (sweet spot) the slip numbers on the three blade run about 14%. At the sweet spot the 3 blade peaks at 6,000 rpm's at top speed of 69 mph.
The four blade bites much better coming up on plane, on top end and in the big stuff. The four blade hits it's sweet spot at a lot higher x dimension than the 3 blade. It runs out to about 70 mph with 50 gallons or so of fuel at 5800 rpm. Slip numbers running about 9%.
Not too bad except the RPM"S are way low and the stern is still buried in the water at 70 from the weight on the back.
__________________
Now... First let me say I know about as much about props and the next wannabe keyboard warrior...
I've watched a lot of vids of other LCB's. With all the weight that I have on the rear, my stern should and it does run deeper than the lighter boats. When the fuel load get's lighter in my boat the stern rides higher and speeds go up accordingly. I like the way the boat performs, but I'm digging for that something to give me more stern lift. If I can get the stern up the boat will run a LOT faster.
From what I can research a longer diffuser tube adds more stern lift. I have noticed the stern riding higher with my full size long tube 3 blade prop at high speeds. I am considering a 5 blade prop for the increase in mid power/cruise fuel economy (less slip) and better rough water performance. I'm considering a Hydromotive P5X or a Maximus (maybe labbed) in about a 24 or 25 pitch.
Suggestions?
08-24-2016, 07:10 AM #56
hound329:
I will gladly do my best to help you. Give me a call.
954 673 1175Brent
2009 LCB 2005 300X
08-27-2016, 02:35 AM #57
That is one pretty boat mold!
1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
09-26-2016, 08:29 AM #58Member
- Apr 2007
- Crystal Beach, Texas
- 33
Prop
Hydromotive props are the only props I have found that will run good on a heavier LCB, and I have tried about everything on my SHO powered rig. I have 2 that I bought new from hydromotive, a summer prop and a winter prop, both 4 blades and they perform great on my rig. I have a 26 in my garage if you want to try it sometime, as it is a backup. We have met before, as I live in Crystal Beach.
