Results 46 to 60 of 100
02-21-2017, 07:45 AM #46
The point alot of people miss is it takes power to accelerate mass, that's why in a drag racing situation the lighter flywheel accelerates the boat quicker. Once the engine is up to speed it is not taking additional power to operate a heavier flywheel, but from a longevity standpoint a lighter flywheel is better, not having all the weight hanging off the top of the crankshaft, let alone what happens when the prop comes in and out of the water with the flywheel trying to twist the crankshaft
02-21-2017, 08:11 AM #47Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Take a 5hp motor with a 5 lb wheel ,run it a 4000rpm. Now replace that wheel with a 5000 lb wheel and see if it can maintain 4000rpm. Or build a flywheel which can draw mass from the outer edge toward the center while rotating.
A student stands on the center of a rotating platform that has frictionless bearings. He has a 2.0 kg object in each hand, held 1.0 m from the axis of rotation of the system. The system is initially rotating at 10 rpm. Determine a) the initial angular velocity in radians per second, b) the angular velocity of the sytem in radians per second after the objects are brought to a distance of 0.20 m from the axis of rotation, c) the change in the rotational kinetic energy of the system as the objects are pulled closer to the center of rotation. d) What causes the increase in rotational kinetic energy? (Assume that the moment of inertia of the platform + student remains constant at 1.0 kg m 2.)
Solution:
a) Use 1 rev = 2 radians and 1 minute = 60 seconds to convert:
10 rev/min = (10 rev/min )(2 rads/rev )(1 min /60 s ) = 1.05 rad /s.
b) Use conservation of angular momentum. We therefore need to compute the initial and final moments of inertia of the system:
Ii = I (student + platform) + mri2 + mri2 = 1.0 kg m 2 + (2.0 kg )(1.0 m )2 + (2.0 kg )(1.0 m )2 = 5.0 kg m 2
If = I (student + platform) + mrf2 + mrf2 = 1.0 kg m 2 + (2.0 kg )(0.2 m )2 + (2.0 kg )(0.2 m )2 = 1.16 kg m 2.
Determine final velocity using conservation of angular momentum:
So that:Ii = If.
= = x 1.05 rads/s = 4.5 rads/s.
c) The change in kinetic energy is:
KE = KEf - KEi = If - Ii = (1.16 kg m 2)(4.5 rads/s )2 - (5.0 kg m 2)(1.05 rad /s )2 = 11.8 J - 2.75 J = 9.05 J.
d) As the student pulls the object in toward the center of rotation, he is doing work on the system. This work goes into increasing the kinetic energy of the system.Last edited by FMP; 02-21-2017 at 10:05 AM.
02-21-2017, 10:34 AM #48
02-21-2017, 11:15 AM #49Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
An infinite mass wheel and an infinitely small HP will take infinite time
powerabout liked this post
02-21-2017, 03:28 PM #50Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
What I wanna know is, how do those ice skaters spin so damn fast with out a flywheel.....
02-21-2017, 03:48 PM #51
02-21-2017, 03:54 PM #52Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Was going to post one with real nice shape just to give an example to the question above.
02-21-2017, 04:41 PM #53Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Mr. Demeanor liked this post
02-21-2017, 07:36 PM #54
The hardest fact about lightened flywheels... They look cool.
FMP, Mr. Demeanor liked this post
02-21-2017, 09:02 PM #55
I know! My poor motor looks so sad. Kind of like its wearing an ugly hat.
21' Paramount
Mercury 300 Promax
02-21-2017, 09:03 PM #56
FMP liked this post
02-21-2017, 09:06 PM #575000 RPM
- Jan 2017
- Waterford Michigan
- 104
- 17
02-21-2017, 09:12 PM #585000 RPM
- Jan 2017
- 104
- 17
02-21-2017, 09:16 PM #59Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
By drawing mass to center axes of rotation. Sample problems above
msm liked this post
02-22-2017, 12:49 PM #60
i've been told for years n years tha lite weight came about for "slowin' down" ta turn more than any other reason.... any other benefit was jus icin'........
