Results 31 to 45 of 100
02-19-2017, 09:01 PM #31
02-19-2017, 09:05 PM #32
02-19-2017, 09:09 PM #33
02-19-2017, 09:11 PM #345000 RPM
- Jan 2017
- Waterford Michigan
- 104
- 17
02-19-2017, 09:15 PM #35
But, if you've had your entire rotating assembly balanced you probably should not swap flywheels. Thats the problem I ran into when mine grenaded but I have no choice but to throw a stock one on.
21' Paramount
Mercury 300 Promax
02-19-2017, 09:18 PM #365000 RPM
- Jan 2017
- 104
- 17
02-19-2017, 09:19 PM #375000 RPM
- Jan 2017
- 104
- 17
02-19-2017, 09:22 PM #38
powerabout thanked for this post
02-19-2017, 09:31 PM #39Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
What you do with the recip depends on the configuration of the engine and how it's mounted. The rotating big end rod balanced with the flywheel balanced with or on it's own the flywheel will be the same. A balanced wheel is a balanced wheel. Merc
02-19-2017, 09:53 PM #40
This is Quality, less than 4lbs. approved for use in ODBA/DSRA/F1
02-19-2017, 10:01 PM #41
Wish I could get something that pretty for my Yamaha without spending a fortune for a one off piece.
21' Paramount
Mercury 300 Promax
02-19-2017, 10:04 PM #42
02-19-2017, 11:43 PM #43
It's $1,000. when in stock
Nothing good is cheap
Nothing cheap is good .We have invented the world; WE see
02-20-2017, 01:36 AM #44
The only benifit to a lightened flywheel is crank flex. Dyno test will not show how a boat will perform on the water. Yes a lightened flywheel will spin up faster but the lost mass will allow the engine to dip farther when the prop loads. The real test would be in the water over a measured distance.
02-20-2017, 08:14 PM #45
Unless he is drag racing this donzi with a data logger the difference between a light flywheel and a stocker is inconsequential. Flyweight stuff is great in a rig that is launched wave top to wave top with nasty rpm spikes. With 1.50 gears and 400 hp he is going to be up there in prop pitch and the heavy bite of a high pitch mirage bravo hydromotive or otherwise will negate much of a spendy flywheel. And it sucks to look like an ass around the docks.
