Results 1 to 9 of 9
    Exclamation Evinrude Johnson 15" Taylor midsection 2.5 1.62 Sportmaster
    This setup is the best bold on mod you can do to a looper or E-tec period. The short mid with BIG gear helps keep rpm down where these motors make power.
    Mid section is in good shape and has new bushings in the clamp.
    2.5 sportmaster has new water pump and seals it is ready to go.
    Comes with shift linkage and brackets so it is bolt on and go, use your factory OMC/BRP cables. I can include a Carb adapter or 3.3/3.4 E-tec adapter.
    It is still running on my boat so it will not be available for a few weeks. I dont have to sell it, its not a fire sale. Only reason I'm selling is I'm building a 12" mid with a sporty.
    I put over 100 miles on this setup last weekend cruised at 4600rpm which is 85mph got 7mpg.
    Wingplate and ram is available also.
    I can crate and ship worldwide.
    $3,750
    Jul 2008
    norway
    Is it possible to use a Evinrude V8 on this mid and sportmaster, asking for a friend
    Adapter plate for v8 will not fit so no.
    May 2019
    Norway
    Where can i get a midsection like that ?
    Bristol, WI
    Quote Originally Posted by Twister24etec View Post
    Sam Jenkins
    Larry Gempp Jr.
    Bristol, WI
    What helm do you run with the side ram Kevin?
    Jr.
    Larry Gempp Jr.
    Aug 2009
    Somewhere
    pm me i have that setup available.
    Columbia, SC
    Midsection etec
    probably late on that set up will it for a 3.3l midsection
    Quote Originally Posted by g-guap View Post
    Jul 2007
    Bermuda
    This is what I need! Need to get me this with a 2.6l etec on top and it would be perfect!
