Page 7 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 91 to 105 of 380
  1. #91
    Glassing the underside of the rear deck
  2. #92
    Aug 2012
    beaumont, tx
    I AGREE!! im really digging the rear deck....cant wait to see it done
  3. #93
    Apr 2007
    cool good job on the splash well delete
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
  4. #94
ID:	300405Layed some 3/4" balsa down on the Inside of the 1" balsa on the outter side of the rear deck tonite.with the weight
    its bending the deck down a little but im thinkin im wanting a bit more curve downward but I think after the sanding of the balsa I will get it where I want it.
  5. #95
    Took the weights off and it set pretty good, 2 1/4" dip from side to side. But will be a full 3" when I shape the balsa down in the middle.
    made a front bulkhead for the rear deck also.
    Attached Thumbnails Attached Thumbnails 20140702_172322.jpg   20140702_172550.jpg   20140702_172331.jpg
  6. #96
    Glued some 1/4" balsa to the upper side wings a few days ago and started shaping them into the concave of the two lower wings. Started out using a hand planer to get rid of the bulk of the balsa but it kept chiping up in chunks. I didnt soak the resin too deep to make the sanding a bit easier. But without the resin all the way thru it had to be sanded insteadn of power planed.
    Attached Thumbnails Attached Thumbnails 20140712_200456.jpg   20140712_200517.jpg
  7. #97
    Aug 2012
    beaumont, tx
    Love it!
  8. #98
    Afternseveral hours of sanding with a DA sander and a strait sander the concave of the upper wing is apparent.
  9. #99
    Right side
  10. #100
    Nowthen, Minnesota
    Cant wait to see this done. Great job so far.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  11. #101
    Nov 2005
    Plaisance, Québec, Canada
    Absolute awsome job keep up.
    Glastron GT 150 W OMC 140
    Glastron GT150 w OMC 235
    Hydrostream Vision with 2.0l 135
    Hydrostream HST w 3.0L 225
    I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
  12. #102
    Worked on shaping these lil pieces from the rear deck onto the side rail to make the transision smooth
    Attached Thumbnails Attached Thumbnails 20140722_175046.jpg   20140722_175023.jpg
  13. #103
    Im not satisfied with the sculpting and sanding of the rear deck. Even using the strait flat sander the balsa sands down but the resin inbetween the squares dont and its all uneven and wavy. And on the outter edges where in building the contures and curves it is more dificult to sand both balsa and resin together to get it the shape I want. So im wondering if I use Bondo to get the shape I want then lay mat on top of it all then another coat of vinylester to top it all off before paint? Or is this not a good idea?
  14. #104
    Charlotte, NC
    I would get a more premium filler like Evercoat, but I don't see why why this wouldn't work.
  15. #105
    I would ruff shape it with a grinder, fill back with resin mixed with Q-cells and finish the shape. Cover with your glass of choice....
