Page 24 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 346 to 360 of 380
  1. #346
    Mar 2004
    Brooklyn Park, MN
    did you run that SRX yet?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  2. #347
    Nope. I need some way to bolt it on. Double lock nuts or something. Theres no splines that stuck out to lock onto or enough threads for the stock nut to get into the lock nut part of the nut.
    What do others use.
  3. #348
    Mar 2004
    Brooklyn Park, MN
    Call DAH, they will send out out what you need.
    http://www.dahpropellers.com/
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. #349
    Tried the SRX yesterday with the wife. It porposed like crazy. Didnt have it on long at all and put the Trophy back on and smoothed rite out. Dropped wife off and went out and did a new top best run of 75 mph. And a plug chop
    Attached Thumbnails Attached Thumbnails 20170814_183709.jpg   20170814_183654.jpg   20170814_183646.jpg   20170814_183211.jpg   Screenshot_2017-08-15-16-49-51.png
  5. #350
    Got a new prop in and had to go out and try it today. A
    Signature ET 26. I was able to get it to 75 mph at 6000 rpm with just myself but super unstable. Then at a sandbar picked up a beach bum and his weight really stablized the Stream and stupid me didnt turn the gps back on BUT i definitely saw 7200-7300 on the tack on a long open run...
    Attached Thumbnails Attached Thumbnails 20170815_121501.jpg   20170815_121556.jpg   IMG_06281.jpg
  6. #351
    Aug 2015
    NE Tennessee
    So if 75 mph @ 6000 with 1.87 LU that's about 5% slip.
    That amount of slip @ 7200 shows 90 mph
    Looks like the cleaver is working for you with it set up like you have it with 2 people.
    Also...jmo...the plugs look a bit lean to me. Maybe pull the plugs and have a look at the piston wash pattern and see better where your a/f tune is at.
    "IF" I'm reading "only" the plug porcelain color, I like a nice toast color.. jm2c...
  7. Thanks roadkill636 thanked for this post
  8. #352
    4 blades give stern lift. Hubs give even more. Notice a trend here? With 10% slip that comes out to mid 80's on the 26p sig. That's moving out real good. You were at 5% slip at 6000 and 75 mph. Hooked up good.
  9. Thanks roadkill636 thanked for this post
  10. #353
    Is my bow too light? Or can all Hydrostreams be lifted up by hand out of the water?
  11. Likes Slimm liked this post
  12. #354
    Quote Originally Posted by roadkill636 View Post
    Lean?
  13. #355
    Rhode Island
    HAHAHA THAT IS AWESOME !!! I wanna try that with my little tunnel hull
  14. Likes roadkill636 liked this post
  15. #356
    Been playing with some props. The 26 Trophy is my favorite so far for all around playing with a boat full of cooler and wife out for the day. It gets up and runs smooth and has the least amount of porpoising. And still runs 72-75 mph with 2 people in the boat. The Ron Hill Signature ET 26 has dont hold tbe bow to good and looses bite and drops the bow hard to the left.... mainly because i have the battery on the left side and my wife is a good 30 pounds heaver than me. Even with the cooler on the right side it still starts to get up then falls to the left from 10 to 60 mph then starts to smooth out and run up to 6000 rpm then hits a wall and cant hardly get over 6000 rpm... if conditions are just right it will lift up onto the pad and nose will drop and then the boat will TAKE OFF smooth as can be up to 7400 rpm!
    I ran a 28 chopper and same thing hits a 6000 rpm wall then with some work i can get it past that wall nose drop and up to 7000 rpms but has lots of steering tourque.
    I took my 27 SRX to Bob Lipton and he massaged the cups a bit and cleaned it up some but havent ran it yet.
    What do i need to do?
  16. Likes W2F a V-King liked this post
  17. #357
    Nov 2013
    Oak Hill Fl.
    I am having a hard time my self driving my Vector. I let a buddy of mine drive it with me in the back and he got it going really nice and stable. But when I drive it I feel like I am out of control. It has nothing to do with the boat just need more seat time and start to feel comfortable driving it. You have to get past the chine walk and learn to control it I am told. Still scares the **** out of me so it is hard to get past it and start to learn to drive the boat.
    I started with a stock 28 Yamaha drag prop. It needs some cup to give it bow lift but it is a good prop to run on a stream. has lots of rake to lift the bow. with the right tip cup it will be a stellar prop I am told.
  18. Thanks roadkill636 thanked for this post
    Likes roadkill636, Slimm liked this post
  19. #358
    Vectors are notorious for being a hand full. Lot of lift built into that hull . Be patient...
  20. Likes dwilfong, texasvector liked this post
  21. #359
    Picked this hyd jackplate ip ladt nite for $500..the guy had it on for 2 outting and didntlike it becausr his steering fitting hit his transom so he bought another jackplate with more setback. This is a Seastar 4" like brand new.
  22. Likes Slimm liked this post
  23. #360
    Got the jackplate mounted. With a quick half arss measurement It sits a bit higher than my 6" Springfield Marine.
    With everything mounted in the highest holes and powered all the way DOWN my propshaft is 1 1/2" below the pad.
    What ya think?
    Attached Thumbnails Attached Thumbnails 20180222_190400.jpg   20180222_190421.jpg   20180222_190342.jpg   20180222_190431.jpg   20180222_190538.jpg
  24. Likes Slimm liked this post
