Results 1 to 4 of 4
    Jun 2001
    Newer SSM water pump plate gaskets vs older plate gaskets
    Hope I can explain this.
    so the water pump gasket on the older twin pinion SSM ( the gasket UNDER the stainless plate) it has 3 evenly spaced areas cut in the gasket under the impeller to allow for water to be sucked up through the plate. The same gasket for the newer SSM units don't have these three even spaced slots. they have a front slot that is similar and a second longer slot along one side of the gasket.
    wondering how these newer gaskets will work on the older SSM's. Gaskets for the older units are NLA, but the gaskets for the newer units are still available.
    anyone ever crossed this bridge before?
    appreciate the info.
    Dec 2001
    As the new ones are Lh and old Rh ....just Flip.....Driveshaft L...R..
    Dec 2004
    Tom,
    Be sure to listen to Dave S, he will tell you the right stuff!!
    Raymar
    ST.PETE FL.
    5 Thread(s)
    I have one some where here . Let me know if u need me to find it and post a picture of one
    SEEBOLD CHAMPBOAT MERCURY S3000
