Results 1 to 14 of 14
    Washington
    1998 mercury 175hp on a 1989 mercury 150hp midsection
    hey guys, new to the site so hope im getting this right. so what i have is a 1998 175hp mercury black max that runs great but it has an XL shaft . my old motor that is a 1989 150 hp blew its power-head. but has the jet pump and a long shaft. so my question is can i swap the 175hp power head onto the older 89 midsection? if so what will it take to do this? and if it doesn't work, what year and hp midsections will work? thanks ahead of time guys!
    Hopedale, IL
    Swap the power heads and go boating again. The adapter plate (between the mid and power head) is what really matters. You should have a direct swap there w/o messing with adapter plates.
    Sunsation 32 Dominator - 496 MAG HOs
    Nothing runs like a Deere when a CAT's on it's ASS!
    Washington
    nice! what should i need for gaskets? id like to have everything prepared and ready to go so i can knock it out in a couple evenings since ill be borrowing a buddys shop. any tips or tricks on this swap i should know?
    Hopedale, IL
    Power head base gaskets and whatever you will swap over or open up to inspect. Pretty straightforward swap really
    Washington
    awsome thanks man! you just saved me alot of money!
    Aug 2009
    savannah,ga
    Just a fyi...pretty much any 2.0, 2.4, 2.5 fishing motor will work on that leg. The racing motors have a different cool strategy than the fishing motors but needless to say they will bolt on as well...probably just won't cool properly.
    Washington
    ok so now that we got that lined out any idea how many bolts hold the powerhead on the 1998 175hp? any tricks to breaking that thing loose? think its seen a little salt but has very little rust anywhere on the motor or block. just some surface rust on the tiller bracket.
    Hopedale, IL
    8 studs I believe
    Pekin, IL
    ten studs
    Team Junk
    Hopedale, IL
    What he said.
    Washington
    any ideas of where i can find a diagram? does the lower cowling come off before the power-head or do i have to dig down in there to get to studs? just trying to compile all the info i can before digging into a great running motor don't want to mess this up to bad lol
  12. #12
    Hopedale, IL
    Go to mercury parts express and plug your serial number in. It will give you a parts breakdown. If you can get a Merc manual they ere not that expensive. I think $75 or so will get you the book that covers 150-225 2.5L engines.
  13. #13
    Dec 2011
    Sunny Oregon
    Quote Originally Posted by TyElrod View Post
    Yes, You have to take the lower cowling off to get the nuts off. No other way. Once you figure out that lower cowling thing its a ten minute job getting it off there.
  14. #14
    Pekin, IL
    4 more screws (2 in front and 2 in back) and a couple wires and you're ready to roll
    Team Junk
