Results 1 to 15 of 29
    ft pierce fl
    300xs open exhaust? raise compression?
    has anyone run a 300xs with a mad efi mid with open snout like on a 2.5 offshore mid? Also have not read any post on cutting dfi cyl heads. I see post where people cut the 3.0 efi o-ring heads. any reason it is not being done on the dfi motors?
    Opening the exhaust is no issue but it will need to be mapped if you want to add some more squeeze.
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
    ft pierce fl
    I am thinking the motor will have idle issues and may have dead spot coming off idle. I guess if a certain someone on here would work a little faster. we will know how it affects it.
    what about the dfi head cutting? has anyone tried raising compression 20lbs or so and get any gains?
    Yea he needs to stop painting chit metal flake and screw it together
    Mar 2005
    Ontario CANADA
    Quote Originally Posted by davemvegas View Post
    Subscribed
    Sep 2008
    vero beach
    HHHmmmm.... Interesting....
    • Hydrostream V-King with a Drag - SOLD
    • STV RR Drag with a Drag- SOLD
    • 18' seacraft c/c 200 merc- SOLD
    • 18' Action Marine Retired & "Wet"
    • STV Needle Nose " The Heat" - SOLD
    • 21' Triad- "The Sipper"- SOLD
    • 26' concept c/c twin 200 Mariners -SOLD
    • STV RR - "Lil Sista" on a Strongback Trailer
    • 18' Action Marine on a Strongback Trailer
    Everybody wants a piece of the pie, till they try it!!!
    Sep 2008
    vero beach
    Quote Originally Posted by Kcraft View Post
    Subscribed
    Here ya go Kcraft...
    I just need to add my (S)...
    Mar 2005
    Ontario CANADA
    Quote Originally Posted by motorheadbishop View Post
    I do prefer the look of a 2.5 style mid that you chose over the 3L X style that I am running...
    Mar 2010
    Holly
    i know on my HPDI yamaha the heads were cut. and i ran 135psi where a stocker would be 115 to118
    22 Talon w/ 300 HPDI
    Bristol, WI
    Etec DI's actually lose HP with extra compression in stock form.
    Larry Gempp Jr.
    2017 RXP-X 300
    2016 Quartershot T3R
    28 Skater
    2004 HydroStream Venom - 3.4 Etec - August, 2011 S&F Boat of the Month
    Jul 2011
    Chesapeake, VA
    What's the compression supposed to be on the 300xs?
  12. #12
    ft pierce fl
    the Manuel shows 100 to 110psi as being good. I know of a few 2013 motors that have 140 to 145psi. my 2007 300xs has had 110 since I bought the boat with 27 hrs. both my 2013 motors have 140. I just swapped my 07 motor yesterday with one of my 13 motors. I am curious if the 30psi will make any more speed. it does not sound any different on the hose. I am sure my 07 motor is not wore out. pretty slim chance since it had 110 at 27hrs and now with about 100 hrs it still has exactly 110psi on all six.
  13. #13
    Aug 2005
    port orchard , wa
    Im curious about that as well.Are there different numbers on the 2013 heads then on the 07 heads?I have a 07 as well,it has a DBR 1.1 kit but ive always wondered what a few more psi would do?I was told there may be issues with the air injectors.
  14. #14
    Mar 2006
    auckland new zealand
    Just my 2cents when I got my 300xs one of the first ones I put it on my 15inch mad efi mid and it was a pig out of the hole and pyros where quite high to.
    They run very lean id want to add fuel b4 cutting heads.
  15. #15
    Bristol, WI
    Larry Gempp Jr.
    2017 RXP-X 300
    28 Skater
