Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    Dec 2013
    c-ville fl
    My '04 250 has been a great motor it moves my cabin boat very well! The locator pin issues I hear about seem to be on the motors turning higher RPMs than the average fishing boat!!
  2. #17
    Aug 2010
    N.Florida
    I'm sure that running them up to the limiter doesn't help but they had a little bit of a problem with locator pins.
  3. #18
    Apr 2009
    florida keys
    I will say when we can mod the emms on them like you can on optis. Mercury is in for a world of hurt!
    Stan carson
  4. #19
    There r modded emm
  5. #20
    Trussvegas
    I would love to compare a 150HO to my franken eagle and see how it does. I am sure it will be better on gas, but the eagle motors start and run pretty well. Mine idles at 600 in gear all day long.
  6. #21
    Aug 2009
    savannah,ga
    Like I tell all my customers...lack of use is the biggest killer of 2 stroke outboards. Do I like the DFI Rudes..no...but that doesn't mean they can't last a while with the right owner...same goes for the Opti's.
  7. #22
    May 2006
    Bankruptcy was late 2001, we recieved notification by Fax from Merc over the Christmas holiday. The first 3.3 was built for 01 year model by omc (took one to a magazine evaluation), the first engines to be BRP built were in 2002. First Ficht was the 60 degree engine built for 1998 model yr, first e-tec was the 3 cyl in 2004 model yr with the 3.3 version in 2005.
    Bankruptcy was December 21, 2000. Bombardier won the court bankruptcy auction for certain Johnson and Evinrude assets in Feb. 9, 2001. The Bombardier built 2002 FICHTS started coming off the production line in Sept. 2001.
    The 1997 150hp FICHT was the first of its breed and was produced starting in 1996.
  8. #23
    May 2001
    Hickory NC
    Correct, Omc built 01 engines in 2000 prior to bankruptcy and should have said for 02 model yr.
  9. #24
    Jul 2004
    Connecticut
    Quote Originally Posted by seahorse View Post
    I feel better now that I waited and found a clean used 2002 Evinrude 250 DFI. It took a while. We've had no problems with it, very good motor and way less noise than I had expected. prior to purchase.
  10. #25
    Trussvegas
    Quote Originally Posted by johnboy 88 vegas View Post
    That means mine is due to break then, because I haven't used a gallon of oil in 2 years since it was rebuilt.
  11. #26
    Feb 2010
    Tarpon Springs, FL
    The very first E-TEC'S were the two cylinder 40-50hp in 2004. I bought one of the first ones for my 20ft pontoon boat. The TPS sticking was the only big issue from the factory and by time it happened on my engine, Evinrude knew about it and sent me a new intake and TPS sensor.
    One example of BRP wasting their money. I fixed it with a few washers or something to that effect. It was to long ago to remember what I did but it was a solid fix. Some Engineer trying to keep his job costing the company millions. What got me is that the intake was exactly the same. Its still in a box somewhere lol.
