Results 91 to 105 of 700
Thread: Outboard World Record
12-25-2013, 11:09 PM #91
Subscribed..... good luck with the project.
Thanks,
Tim Bostic
Hoss Marine Propellers
www.hossprops.com
918-479-5167 (shop)
Pugh Hydro w/260 Merc - 12" mid
1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
"New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
12-25-2013, 11:36 PM #92
So the joke the other day at lunch was that my boat wasn't going to float very well with all the holes in it .. since it's just the bare thin wall chromolly tubing ...
Anyway, I'm not a boat builder, just a stupid welder. They told me to fill this black hole ..
So where it skinny's down in the front, I did the same ..
Where the drivers legs and lower torso will ride, every box has a diag bar thru it to make a series of triangles. Under his butt is a X to make four smaller quadrants.
Where they put a body line below the drivers helmet is where we will tuck the "helmet bar" that ties the upper part of the cage together ..
It's really not my place to show or talk about sponson's, their attachment points, the rear deck or anything else outside of the main fuselage .. But I cant help but think that from within the 200+ mph view , there is more than enough room to get comfy ...
And I think the glass guys in here will say that this is a quality built part , pulled from a dedicated mold. I know my local carbon guy says that to get carbon to bend into tight area's , you have to vacuum bag it .. this looks pretty tight to me ..
Last one .. I love NACA ducts .. I use them to exhaust any pressure building up in the front section of my lawn dart. and two more as air conditioning inlets , they tend to keep the windshield and visor from fogging up ..
12-26-2013, 06:24 AM #935000 RPM
- Nov 2007
- London, UK
- 257
12-26-2013, 06:27 AM #94
Very nice and impressive work from a ****** welder
12-26-2013, 07:24 AM #95I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
12-26-2013, 07:38 AM #96
good lordy that is sexy.!
awesome work everyone.!
Dago.
12-26-2013, 10:27 AM #97
I'd offer up my welding experience but I see you got that covered so can I check the air pressure in the trailer tires!
Laser 1550 ...under construction with a serious weight loss
Motor 2.4....undecided on hp yet
12-26-2013, 11:31 AM #98
that is AWESOME!!!!!!!!!!!!!!
98 XR2001 Drag w/pro stock mota
12-27-2013, 11:46 AM #99
Capsule
Rick I assume that when you run on the rope your plan is running under the "Unlimited Outboards" rules
92 Appendix H
U n l i m i t e d O u t b o a r d s
Unlimited Outboards must comply with all rules, regulations, and safety requirements for Professional class boats unless a specific item is superseded as noted below: If boat has a canopy, seat belts or air supply, all three must be used (Canopy, seat belts and air supply)
Capsules - Capsules in Unlimited Outboards shall be of an APBA type design, having a one half (1/2) inch minimum thickness capsule wall constructed of balsa, carbon fiber, and Kevlar materials. A three sixteenths (3/16) inch minimum thickness poly-carbonate canopy shall be attached to a five eighths (5/8) inch O.D. (outside diameter) X .058 inch minimum wall thickness chromemoly tube frame. The canopy frame is to be attached to the capsule by means of hinges and two latch assemblies. All capsules, regardless of manufacturer or type, must be fully enclosed, and be designed using state-of-the-art technology in an effort to minimize serious injuries to the driver in the event of an accident. It shall be the responsibility of the boat owner to select the designer and/or manufacturer that best meets his standards for a high quality, crash worthy capsule. •Air Supply - All rules pertaining to the driver’s air supply system must be followed unless physical limitations prevent the air tank from being located inside the capsule. The tank may then be mounted securely on the back of the capsule. In that case, the tank, regulator, and all air lines must be totally enclosed in such a manner that water cannot contact and pull them loose in the event of a crash.
•Latch Pins - Latch pins (latch assembly pins) must be three eighths (3/8) inch minimum diameter push only type with a spring load of at least five (5) pounds. The ring should be attached to the body of the pin assembly rather than to the end of the release button. If necessary, a spacer must be used so as to position the release head of the pin no deeper than one (1) inch from the outside of the capsule.
•Side Load Pins - Side load pins, designed to prevent the capsule canopy (or windshield) from shifting to either side in the event of a crash, must be installed in the immediate vicinity of each latch assembly (similar to SFI 36.1/.2/.3 capsules). The pins must be a minimum one half (1/2) inch chromemoly.
Parachute - Parachutes are not required in the UO class.
Rudder - Rudders shall be optional but if used shall be a minimum of three eighths (3/8) inch thick at the clamshell, and the clamshell itself shall be a minimum of three eighths (3/8) inch thick on each side of the rudder. The rudder must extend a minimum of one (1) inch below the bottom tip of the propeller when said propeller is installed on the motor and positioned in a vertical manner.
Steering - Open cable steering must have said cable a minimum of three sixteenths (3/16) inch in diameter and the cable ends must be double clamped and taped. Motors on Unlimited Outboards utilizing hydroplane hulls must be locked in a straight ahead position and the steering accomplished by a separate rudder assembly.
These are the rules as listed in the 2013 Lucas Oil Racing Rules and Safety Requirements
Rick"Conklin Racing" M/E 0494
Sponsers,Conklin Racing, Speed-N-Sport Marine
12-27-2013, 01:02 PM #100
rick i thought the rudder was still optional did it get changed again for this year
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
12-27-2013, 02:46 PM #101
Read it again "
Rob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
12-27-2013, 04:34 PM #1025000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
What about the last line in the "steering" section?
12-27-2013, 04:40 PM #103
21' Paramount
Mercury 300 Promax
12-27-2013, 05:31 PM #104
for sale
12-27-2013, 05:34 PM #105
for sale
