Results 1 to 6 of 6
    Netherlands
    What is the best prop for my seaquel 600 xs
    Hallo,
    I have a seaquel 600 xs build by Gav. I bought it from an other member in the Netherlands a few months ago maybe some of you know the boat with an 300 mercury XS on the transom :P. My old boat was a phantom 21ft and the New one is totally different . I drive it by a 200 hp Yamaha 2.6 carb. with a 1.86 gear case. Boat hull design is with a very large vented notch and i got a manual cmc lift on the transom. torpedo is even keel with the V-bottom
    I try lots of props but it is very hard to find the best one. did I need more bow lift our a little stern lift ?
    Props I tried:
    - 25" Tempest plus 5800 rpm and 109 km-h gps
    - 27" Tempest plus 5400 rpm and 111 km-h gps
    - 26" Cleaver 6000 rpm and 106 kmh - gps
    - 26" 4 blade ron hill signature semi cleaver lap finished 6100 rpm (hit the limiter) and 110 km-h
    - 28" Chopper II lap finished terrible on my boat 5200 rpm lots of slip and 107 km-h gps
    Tempest plus and the 4 blade signature works the best till now but how can I get more speed? Our is this already the max.
    rpm ranch of my Yamaha is 4500 ~ 5500 rpm but I like to run a little bit more for more torque when I drive with more people.
    I saw on e-bay some new Ron Hill 28" 4 blade signature's semi cleavers but when I calculate on prop calculator the 26" 4 blade got lots of prop slip but the hole shot and lift is very good . can I get more speed with an 28" ? or only more prop slip and no gain in speed?
    Greets from the Netherlands,
    Corne
ID:	287942Click image for larger version.
ID:	287943Click image for larger version.
ID:	287944Click image for larger version.
    Netherlands
    nobody experience with this boats? What kind of props I must run at how many rpm for the best results with an 2.6 yammie ?
    Boat: Hydrostream virage
    Engine: Mercury 300 XS DBR 1.3
    Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
    Max speed: 113mph
    Apr 2006
    Belgium - near city of Ghent
    If you're hitting the limiter with a certain prop, then there is room for more pitch. Were you just barely touching the 6100rpm ?
    I'd go with a 28P Ron Hill and test, expect the acceleration to be a bit worse, but you'll see more top end.
    Sep 2010
    long island,ny
    27 or 28 HOSS HPD....You'll get stern and bow lift.
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
    Apr 2006
    Hoss hyperdrive... nice ! www.hossprops.com/Hyperdrive.html
    Hi, Nelson must this be the 3-blade and 14,5" diameter ?
    Sep 2010
    long island,ny
    Quote Originally Posted by Toffy View Post
    Yes......hard to find a used one ....Call Tim at Hoss .
