Results 31 to 45 of 62
11-29-2013, 05:50 PM #31
11-29-2013, 06:27 PM #32
I think the constant surfacing is the killer rather than holeshot and power loading
During holeshot and loading, the prop load is very even across the whole blade. When running surfaced, half the blade is loaded, the other half isnt, and its loading/unloading and an incredible rate. We've have all broken off a piece of metal by flexing it back and forth until it breaks and thats what is happening to a surfacing prop.
I say this because I have broken two props with my little stock 130 and it happened as soon as I started running them real high.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
11-29-2013, 07:31 PM #335000 RPM
- Nov 2007
- London, UK
- 257
Someone at lake coniston this teat had all 4 blade break on one run. Every blade in the same kindred place. 1/2 way up from the root.
11-29-2013, 07:33 PM #34
11-29-2013, 07:36 PM #35
so it sounds like beef and Tom are the hardest on props, note to self do not loan them any props, Matt
11-29-2013, 07:52 PM #36
How is the handling when you break a blade off? Does it get wild or not? Is it a big issue or does it just vibrate?
CL6fan57-88
11-29-2013, 08:04 PM #37
11-29-2013, 08:27 PM #38
Looks like you should be able to write beef off on your taxes lol I just took mine off I don't even know how it was still going that prop had been spinning on the hub so bad over the weekend I guess when I pulled a down boat on friday I had a little vibration looked at it no bends or cracks but it is actually a little out of line on the hub and had smeared the prop and thrust washer together bad
Check out my onlyfans....
Subscriptions start at 1 gallon 100LL a month
11-29-2013, 08:58 PM #39
11-29-2013, 10:07 PM #4013' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
11-30-2013, 06:00 AM #41" The Fleet of Old Boats "
11-30-2013, 08:16 AM #425000 RPM
- Jun 2006
- miami
- 503
- 39
don't you sleep Tom? I left my cooler and my scissors in Gina's kitchen. going to the key's in two weeks to replenish the stash for your next lobsterfest.
11-30-2013, 10:12 AM #43
11-30-2013, 11:40 AM #44
I just find it hard to believe that Beef would be hard on anything
18 Action 225 Promax
11-30-2013, 12:03 PM #455000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
does performance propellers make a cleaver?
