Page 9 of 32 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 LastLast
Results 121 to 135 of 473
  1. #121
    Use acid for the aluminum and get a lisle style rigid hone on ebay for around $100.00
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
  2. #122
    Aug 2010
    N.Florida
    What grit do you finish with on a rigid?
  3. #123
    I think mine are 180 and Finish with the ball then brush/soft hone
  4. #124
    Austin Tx
    Sequence.........
    1 Ball
    2 Rigid
    3 Brush
  5. Likes Laker liked this post
  6. #125
    May 2001
    The Villages, Florida
    I agree with 6Killer on order, you need the rigid right before a brush to get proper cross hatch
  7. Likes Laker liked this post
  8. #126
    Singapore/Melbourne
    looks like I need to buy a finishing brush
  9. #127
    Aug 2010
    N.Florida
    +1, what does it take to bore a 2.7l to 3.0l? Seems to be some mixed oppinions.
  10. #128
    Aug 2011
    Lake Mälaren, Sweden
    Started to "clean up the rodslots" today.. Do you guys recommend anything else besides the grinding I've aleady done, shown in the picture? (Dont dare to grind deeper due to thin material.
    Do I have anything to gain by grinding a shallow slot towards the boostport, shown in picture?Click image for larger version.
  11. #129
    Aug 2011
    To the top...Click image for larger version.
  12. #130
    Captain75 By cleaning up the rod slots are you smoothing out the rough casting? Keep up the GREAT posting of pics --- Great info. Gary
  13. #131
    Aug 2011
    yes I'm trying to remove all the rough casting and sharp bends(shown in the other crankcase picture) I'm still a bit abivalent weather I should feed the boostport directly from the crankcase entrance or not. You could easily improve the flow by removing the lower sharp edge on boostport lower feeding window and thereby allow some of the freshcharge to direct enter the transferduct(the edge I'm pointing at with the file in earlier picture)
  14. #132
    Austin Tx
    The bigger "bang for your buck" would be to add finger ports. The 2.7 has plenty of meat for doing that.
  15. #133
    Quote Originally Posted by 6Killer View Post
    Is there an echo in here
    If you do the rod slot like that you better take some time to stuff the crank case. The more you remove the more you need to fill. There is not much meat on the 2.7 in that area (atleast compared to newer blocks) and your not looking to turn it 9k.
  16. #134
    Aug 2011
    My boat is mainly used for skiing and tubing and I don't want to raise the powerband
  17. #135
    Austin Tx
    Fingers will add torque across the board.
    If you are not proficient at tuning, all your mods will be a waste......
Spinelli Props
