Page 7 of 32 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 91 to 105 of 473
  1. #91
    Aug 2010
    N.Florida
    Quote Originally Posted by Captain75 View Post
    intakes matched an polished
    You mean intakes matched and sanded, right?
  2. #92
    Singapore/Melbourne
    Quote Originally Posted by wanagofass View Post
    and the centre main bolt cavity's filled up
  3. #93
    Aug 2011
    Lake Mälaren, Sweden
    Yes sanded!
  4. #94
    Aug 2011
    Do you fill them with epoxy after bolts are torqued?
  5. #95
    Singapore/Melbourne
    I jam paper in there then finish off with RTV ( not silicone crap) to hold it in
    Should anything go wrong the engine can eat all that.
  6. #96
    Aug 2004
    Venice, Florida
    Just a heads up I used to use RTV around my intake stuffers but ethanol fuel was turning it to goo and when I pulled my engine apart I found that crap all over.
    I have a small Yamaha NOT a small Johnson
  7. #97
    Singapore/Melbourne
    No ethanol where I live....its a gift from GOD!
  8. #98
    Easiest way to fill the main counterbores is shove shop towels in them and then fill the last 1/2" with A/B putty, or some kind of stick epoxy.
    Kevin
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
  9. #99
    Aug 2010
    N.Florida
    was the block decked in relation to the crank so the timing will then be the same if the ports are same height?
    ( and the bores are pointing at the crank, loopers are bad for that)
    I think you may have misunderstood me a little in what I was saying is that the ex port timing has definitely been raised but I can't accurately measure port height from the deck surface(not that it's ever an acurate measurement anyway)since the deck height has been altered.
  10. #100
    Aug 2010
    N.Florida
    Quote Originally Posted by Mr. Demeanor View Post
    That sucks b/c that's what I was gonna use around the reed blocks.
  11. #101
    May 2001
    The Villages, Florida
    Get some good plastic rod that is the correct dia. and cut it to length then tap a set screw thru the block to hold it in place.
  12. #102
    Singapore/Melbourne
    I heard red necks just leave the socket in there...lol
  13. #103
    Aug 2010
    N.Florida
    That works ok, but it adds more weight.
  14. #104
    Aug 2011
    Still in the need of jetting advice...
  15. #105
    Aug 2010
    N.Florida
    .078s were very rich in my ported motor, but it was 3.0 and stock crankcase.
Diamond Marine
