Page 5 of 32 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 61 to 75 of 473
  1. #61
    For what your trying to do adding finger ports would benefit you more then widening transfers. I would think more area in the transfers would make it lazy in the low rpm your trying to make it run.
    I ported my brothers 3.3 and all I did was clean up the intakes attempting to maintain the stock angles but squared off boost and fingers at the roof. Exhaust is stock on the outside and ~.070 higher in the center. It is no where near tuned yet and it turns a 15x34 ET 72-7300 with only 16* 4 stroking the whole time.
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
  2. #62
    Aug 2011
    Lake Mälaren, Sweden
    I have the tools to cut fingerports, although I can't se where to put them due to the piston ring stops. I'm thinking about welding the block on the outside to be able to cut a slot to feed the boostport from the crankcase, my only worry is weather I will loose low end torque due to less crankcase pressure...
  3. #63
    Singapore/Melbourne
    build a custom intake and move the reeds closer to the crank?
  4. #64
    Your better off leaving it piston ported and cutting shallow fingerports then welding. If you add that much material all the heat can warp the block and require it to be line bored. I have seen people use Epoxy and it works but again for what your trying to do I would just cut them shallow. I have seen evolution blocks with shallow fingerports because the old blocks do not have the FP bosses in them.
    Can you bore it to 3.685 and use OCean pro finger ported pistons?
  5. #65
    Aug 2011
    still the problem with piston ring stops...
    I have moved these on bike pistons before, but it's hard to make them stay in place.
    you almost need to put them between exh and main transfer to mke room for the fingers.
  6. #66
    The late model looper pistons have the locator pin in the finger port from the factory. This was supposed to keep the pin cool but they still had big problems. The latest wisecos have moved the pins out of the ports. Use the later wisecos give them .002 more clearance then a cast piston.
  7. #67
    Austin Tx
    Just welding for the fingers is not an issue. Welding down by the flange is where you get into sealing issues. My V4 was welded everywhere. (Behind the liner motor) I sealed the case halfs with RTV, it worked just fine.
  8. Likes Laker liked this post
  9. #68
    Singapore/Melbourne
    one day someone might create a modular mold/plug and cast v4/6/8 with tons of behind the liner aluminium and open exhaust chest like a merc/old omc
  10. #69
    Aug 2010
    N.Florida
    +1, I have an Evo block that was built up with epoxy and finger ported, the finger ports are very square and way deeper than stock closed decks. But that motor is very lazy untill ~3kish on my average layup 4 seat mirage with a 28 Hoss that hooks up pretty hard.
  11. #70
    Aug 2011
    Another question;
    anyone familiar with the cast thickness in the exhaust chest??
    I'm tryin to straighten out the exhaust passage from the port windows and further into the exhaust cavity. This is most important when it comes to cyl nr5 & 6, where the gases need to pass a 90deg turn. The reason I'm asking is because I'm afraid of grinding throught the wall of the exhaust cavity.
  12. #71
    Singapore/Melbourne
    does anyone have a copy of the old SST 100 APBA engine specifications that shows the porting?
  13. #72
    Nov 2007
    London, UK
    Nice thread people! I still have 2 3.3s I can do something with. Been wondering what the porting would do if anything with stock etec electrics.
  14. #73
    Quote Originally Posted by wanagofass View Post
    How high is the exhuast port? If you stuff the CC a it should help wake up down low.
    Quote Originally Posted by Captain75 View Post
    Another question;
    The chest on your 2.7 is the best stock chest they ever put on a block. Just clean it up a bit no need to do major surgery on a low rpm motor.
    Quote Originally Posted by phantomuk View Post
    A ported E-tec will burn down without a map change.
  15. #74
    Alabama
    I have two 100sst motors. What measurements of the porting are you wanting?
  16. #75
    Singapore/Melbourne
    Quote Originally Posted by Freddie Webb View Post
    Hi Freddie
    I wondered if you had the old APBA tech sheet that has the port diagram?
    thanks
Diamond Marine
