Page 32 of 32 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Results 466 to 473 of 473
  1. #466
    Singapore/Melbourne
    Quote Originally Posted by Captain75 View Post
    The barrier you are supposed to add between the combustion chambers IOT prevent cooling water to pass. Supposed to be done when running open deck heads on a closed block.
    got it.
  2. #467
    Aug 2011
    Lake Mälaren, Sweden
    Kind of low tempo over here during the holidays, but some smaller details in place, like drilling and tappning the closed deck block to accept the open deck check valve:
    Btw does anyone know the difference between these to types of main bearings?
    Newer design?, better?
  3. #468
    Aug 2011
    No ideas on the bearing differences?
  4. #469
    MIAMI FLORIDA
    I don't know for sure but probably just a different supplier, new ones look like the one with circles on the sides not the raised areas... A more solid cage edge may retain oil better..Dave
  5. #470
    Aug 2011
    Quote Originally Posted by H2OPERF View Post
    Thanks for your reply and thoughts!
  6. #471
    Any difference in roller size. I measured between Merc and ProMarine on rod roller and Merc was smaller. Shorter - .0165
  7. #472
    Aug 2011
    Thanks, FMP!
    I’m on vacation on the Canary Islands, but I will check this when I get home to Sweden and post the result!
  8. #473
    Aug 2011
    Here are the resultats. Sorry but my mic only shows mm.
Diamond Marine
