Page 23 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 ... LastLast
Results 331 to 345 of 740
  1. #331
    Aug 2011
    Lake Mälaren, Sweden
    Started for the first time this evening -on the hose.
    After filling the fuel system with the primer bulb, it fired right up!
    After clearing all the oil from the cyls it sounded good. Didn't want to rev it at all, but it felt really crisp on the throttle.
    However there is a problem; I am having a hard time getting the reverse gear in. Gear cable is adjusted to maximum length, but it is still hard to get the reverse gear in when turning the prop by hand. I have never removed the lower unit before, but it feels like something was assembled wrong!? Usually I have about 10mm of threads left on the adjustment screw attached to the shift cable.
    I must be doing some beginners mistake!?
  2. #332
    Aug 2010
    N.Florida
    The shift rod threads into the lower, the installed hieght is probably off.
  3. #333
    Quote Originally Posted by Captain75 View Post
    Congradulations on gettin her fired up!!! Reverse should not be a big problem. Gary
  4. #334
    Aug 2010
    N.Florida
    Double post.
  5. #335
    Aug 2011
    Think I cured it!
    Pulled the lower unit, measured the distance between lower unit mating surface and center of the hole in the shift rod upper end. Fund some thread with the proper measurement(appx 55,7 mm). Rotated the shift rod until I reached the proper measurement, and now it works!
  6. #336
    Nov 2013
    Norway
    Gratulerer / congratulations. Do you have a picture of the boat with the engine on it ?
  7. #337
    Well done, let us know how she runs!
    The metric shift rod measurement is "greek" to me
  8. #338
    Aug 2011
    Sorry...
    "For a 20" (L) engine, the spec is 21-29/32" to 21-31/32". Midpoint of this is 557.212 mm for you metric system users. For a 25" (X) engine, the spec is 26-29/32" to 26-31/32", with the midpoint in metric being 684.212 mm. This distance is measured from the gearcase mating flange to the center of the shift rod attachment hole, with the gearcase in neutral."
    I found this in a thread on the forum.
  9. #339
    Aug 2011
    Quote Originally Posted by Trommehinne View Post
    I will post a picture!
  10. #340
    Aug 2011
    Boat in water and first tests made...
    Clearly alot moore power!
    idles perfect!
    Cruised at appx 4000rpms, then stabbed the throttle; holy, what a punch!! Even my wife loved the sound.
    Despite all this great news, Motor is still a bit lazy when stabbing the throttle going from idle, not really bogging, just don't feel like the mixture is optimal, it takes a few seconds and then, boom! I haven't yet engaged the primer to decide weather she's rich or starving for fuel. Currently running stock main jets (62D), mid range orfice #14, idle is richened from stock (#48) to #32.
    I know that some of my recirc valves not are in optimal shape, perhaps some of them needs change, just don't feels like they would affect this condition to this extent!?
    I will try to better the holeshot by creating a small gap between the cam roller and cam, in order to give it some more ignition advance on pickup. I don't really want to push hard because of the stock main jets.
  11. #341
    Aug 2010
    N.Florida
    Is it a pretty consistent rpm that it comes alive at?
  12. #342
    Aug 2011
    Quote Originally Posted by wanagofass View Post
    Yes, but right now my tach isnt working properly.
    The goal is to get it to pull hard directly when you touch the throttle!
  13. #343
    I dont remember exactly what you did to the engine but I would not run stock main jets any more
    Glad its running good.
  14. Likes Laseraddict liked this post
  15. #344
    Aug 2011
    Fingers, exh widened, all ports/block casting matched, rod slots, intakes, exh chest, drilled LU...running stock reeds for the moment. ​No changes in port durations!
    I agree on the jetting!
    I haven't buried the throttle for more than 5-7sec, due to the risk of running lean. I have several jets of stock size, My intention is to drill them to .068 specs.
    How much will main jetting affect take off?
    Has anyone tried/felt the difference between good/bad recirc valves?
ID:	298468Its hard to describe in words... Here is the portmap. Doesn't show all the "behind sleeve" work though...
  16. #345
    May 2001
    Hickory NC
    Drilling jets is not a good idea as a 62d is not .062 and a drill will also leave a swirl which effects flow. While jets are not cheap better than pistons. Port timing may be the same but you have added fingers clean up transfers, boost,
    Changed exhaust shape any one of which can change jetting
  17. Likes Laseraddict liked this post
