Page 20 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 ... LastLast
Results 286 to 300 of 740
  1. #286
    Nov 2013
    Norway
    Hello Captain. It is interesting following you, i have a 225 looper and i like how you do with your engine.
    Hvor i Sverige holder du til? I live close to the Swedish border.
    Hilsen Ketil.
  2. #287
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by Trommehinne View Post
    Hilsen Ketil.
    hej Ketil
    jag bor i närheten av Stockholm
    hälsningar Anders
  3. #288
    Aug 2011
    Slow progress is being made...
    Pistons have got some dimples to help prevent scoring and better the lubrication.
    Added lube holes for the wrist pins aswell.
    Right now trying to get all pistons to weigh the same...Click image for larger version.
  4. #289
    Aug 2011
    Honing finished, first a round with stones, finished with 320grit ballhone. Fingers coped fine...
    Now I am a bit worried that my wrist pins became to small after cleaning, I can easily put them in by hand, and they can almost "fall out" if you turn the piston sideways. Meter shows 0,03mm play between piston boss and wristpin.
    Do I need to change?
  5. #290
    SE MN
    That is .00112 In imperial if that helps anyone. .001 clearance would fall out easily.
  6. #291
    Aug 2011
    I know that They can't fall out due to the clips, it was just a way to describe the actual fit.
  7. #292
    SE MN
    I just translated the amount of clearance for the non-metric.
  8. #293
    You should be able to slide them in by hand. How did you clean them?
  9. #294
    Aug 2011
    I sat them one at the time in a machine like this, cleaned them while rotating at high speed, using 600grit wet paper...
  10. #295
    I can measure a stock one when I get to shop later and maybe we can figure out how much you took off.
    Worst case I have about 60 stock pins sitting in the scrap bucket, you can have 6 for free but shipping might cost more then new ones
  11. #296
    Aug 2011
    All of them about 0,944" some of them 0,9445" in the bearing area.
    measurements taken with a digital caliper(couldn't get my micrometer to work properly)
  12. #297
    8 Post(s)
    I think the pins are metric?
  13. #298
    Aug 2011
    They are probably 24mm from factory, I altered the scale in order to hopefully recieve answers from the US guys...
    My pins measure appx 23,98mm, which according to my digital caliper, is the same as 0,944"
    My concern is weather to much play can make the wristpins destroy the piston bosses?(make the hole oval)I don't think spinning pins would destroy the bosses, its the rapid direction changes that worrie me...
  14. #299
    Aug 2011
ID:	295742All pistons ready, heavy ones goes with light rods...
ID:	295743Plugged the predrilled relief roles, reachable when motor is assembled, if I want them opened...
ID:	295744The three threaded exhaust relief holes on a newly painted lower unit...
    Now I am just waiting for my new wristpins and upper crank bearing.
  15. #300
    May 2001
    Hickory NC
    Get the pistons to weigh the same the rods also putting the heavy pistons with light rods is not nearly as good as weigh matched parts. You will need the exhaust holes for it to idle without loading up, also helps low end throttle responce. Personaly I would remove the lower part of the can.
