Page 18 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 ... LastLast
Results 256 to 270 of 740
  1. #256
    go to your brp dealer and get a few cans of engine tuner and soak them in a container for a couple three days.
  2. #257
    Aug 2011
    Lake Mälaren, Sweden
    Aint such dealers around...
  3. #258
    May 2001
    Hickory NC
    Leave those holes open that would not dry stack the engine, they are low speed exhaust holes and for your use needed. I would not dry stack for your application. If the old rings break coming out its not a big deal, I use the old rings to clean the grove.
  4. Likes Laseraddict liked this post
  5. #259
    Aug 2011
    Once again -best ball hone grit for my application?
    Anyone used ball hone on a fingerported motor? Will it work?
  6. #260
    London,Canada
    Quote Originally Posted by Captain75 View Post
    Forgot an issue in my last post; pistonrings...
    I am doing preparations to drill fingerport windows and I want to get rid of the old rings.
    The upper ones are easy, the lower ones on the other hand are badly stuck, how do I get rid of them without having to break the rings? How about cleaning -scotch brite? Diesel?
    Funny thing is that all cyls had 100+ psi with all the lower rings totally stuck and a bad starter battery...
    Heat the piston ring area with a torch...the ring will expand and will break itself loose....then clean the piston groove area.
    great thread!
  7. Likes Laseraddict liked this post
  8. #261
    Aug 2009
    Florence SC
    Do you not have access to an automotive type machine shop? Any shop worth a Damn would have a honing cabinet simular to the
    Sunnen CK-10 ( older) or the CK-77. they will leave the proper crosshatch for the best ring seal.
    Sorry, but a good/reputable shop, wouldn't get caught dead with a DINGLEBERRY hone in the shop.
    Only way to go. period !
  9. #262
    phoenix, az
    I use a 320 grit flex hone... 2-3 light slow passes in and out, reverse drill, 2-3 more light slow passes in and out, move to next cylinder. I also have slotted finger ports, just like yours. Worked great for the cross hatch ​only.
  10. #263
    Aug 2011
    Quote Originally Posted by lokinutz View Post
    320grit flex hone on the way...
  11. #264
    Aug 2011
    I've read i other threads about a certain cooling mod to make sure that an airpocket isn't created in the top of the block... Have I understood it right? How is this mod done?
    pictures!?
  12. #265
    Aug 2011
    pictures!?
    no ideas?
  13. #266
    Sep 2009
    iowa
    I'm not 100% sure, but I think that's a closed deck mod.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  14. #267
    Aug 2011
    First piston drilled for the fingers.
    maybe enlarge them a bit further down...
  15. #268
    Aug 2011
    Recieved my 320grit flex hone today, I will take your advice and try the method you stated!
    another thing; Stock Pistons, are they coated on top with some black coating? I figured they were just burnt, but it seems almost impossible to get rid of, even with oven cleaner and scotchbrite...
  16. #269
    Might be the picture but I would Angle fingers up a bit more.
  17. #270
    Aug 2011
    I've tried, its hard due to wrist pin.
