Page 10 of 32 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 LastLast
Results 136 to 150 of 473
  1. #136
    Singapore/Melbourne
    Stuffing a looper?
    is milling the inlets an easy way to do that?
  2. #137
    Quote Originally Posted by Captain75 View Post
    My boat is mainly used for skiing and tubing and I don't want to raise the powerband
    Hogging the rod slots too much will hurt your primary compression but its necessary when you want a motor to twist up (higher rpm). There are plenty of threads about what rod slot mods work and dont work they are about as long as the oil debate threads
    Fingers will help grunt everywhere, increasing volume of CC will not help you do any skiing or tubing.
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
  3. #138
    phoenix, az
    Quote Originally Posted by 6Killer View Post
    If you are not proficient at tuning, all your mods will be a waste......
    And there you have it.
    With what you want to to do with the boat, I would stop grinding and run it. Most importantly, with what you have already done, I think you need compression. 140 lbs + or - 5 lbs. Run good fuel and xd50 oil and enjoy boating. You should already have 331490 heads. If not, get some.
  4. #139
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by lokinutz View Post
    I've done quite alot of twostroketuning in the past, so I think (and hope..) it will be ok. None of the port durations has been changed. Sleeves and casting has been matched and rodslots cleaned.
  5. #140
    Singapore/Melbourne
    Anyone tried to make a 'tuber' looper like they do non behind the liner Mercs?
  6. #141
    Aug 2011
    tuber!? Whats that?
  7. #142
    Aug 2011
    Do you have any thread-tips? I'm probably using the wrong words since I'm not native speaking...
  8. #143
    Aug 2010
    N.Florida
    IMO, with the info I've gained from talking to various omc people, is if you're building a bridgeport for -7500rpm it has plenty of exhaust, what it needs is intake (fingerports), port cleaning, and intake stuffing. I plan to do just that on one of my 2.7s for my flats boat.
  9. #144
    Most people just putty or weld up the side of the block so they can bottom feed it like a 3.3. There is no boss in the rod slots like there are on 3.3s.
  10. #145
    Aug 2011
    Bottom feed?
  11. #146
    Aug 2010
    N.Florida
    The ports feed from the bottom instead of through the piston window.
  12. #147
    tuber!? Whats that?
  13. #148
    Sep 2009
    iowa
    The question I have is, can you make a Bridgeport spin 7500 or more without adding finger ports?
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  14. #149
    Jun 2001
    South East Georgia
    We have a stock ported 2.7 on a lighter weight Vector it's got big bore carbs and Chris Carson reeds and unlimited packs and it turns a 14 1/2 x 27 3 blade Dr 3 and runs out of steam at 7400.
    TMc
    1984 Allison XR2002
    1987 2.7 Fuel Injected Evinrude
    16" Taylor mid
    Brucato ACU.
  15. #150
    Sep 2009
    iowa
    Quote Originally Posted by TMc View Post
    I drilled the limiter on my stock packs and it hits a wall at 6500-6600. That's a 200-300 rpm increase from before. I've been following this thread to try and figure out how to get mine to pull that high without finger ports.
    1987 evinrude 200xp
Mazco
