Results 1 to 6 of 6
    Aug 2003
    Philippines
    Straight skeg vs swept skeg on sportmaster
    In a single engine application is there a marked advantage to using a swept skeg vs a straight skeg other than the built in torque tab? That can be epoxied on the straight skeg anyway.
    Alot more skeg. If your running really high you need all you can get. JMO
    More skeg the better but swept gives the tab a bit more leverage.
    I know guys who have been 127+ with a strait skeg and a tab on it.
    Jun 2002
    Northern Utah
    I'm using a 3.0L straight skeg sporty with a Bob's add-on tab on a 21' Checkmate. The tab really helped the handling. I run the engine high, often 1"-2" above the pad. It seems to work well but I've also wondered if I'm missing anything by not having a swept back skeg?
    Dec 2012
    HUDSON, FLORIDA
    i run a swept skeg but mounted torque tab straight worked great 0 torque no hyd steering.
    Dec 2012
    HUDSON, FLORIDA
    epoxy is the way to go you can hand form it to a nice curve i use the hardware 2 part comes like a cigar shape just rough up edge of skeg mush the putty roll it on flat surface like a worm use saran wrap a your thumbs and form it on skeg looks factory stays on
