Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 81
  1. #46
    Oct 2013
    Mammoth Cave Kentucky
    I'll have to put my jack plate spacer back in if I go much higher. I prob got another 1/2 and then I'm topped out.
  2. #47
    Jul 2013
    Athens, TN
    you could always move the motor up on its bolts to the jackplate, but thats probably why that spacer plate is the way it is.
    1984 17vee Bullet w/1985 Johnson 150gt (bob's nose cone, hydrodynamics custom 8in. jackplate, custom skid plate and foil, and 26p trophy plus) currently 70mph tournament loaded.
  3. #48
    Oct 2013
    The equation (rpms x prop pitch devided by 1052 x gear ratio ) has me at top speed of 71mph.
  4. #49
    Jul 2013
    Athens, TN
    i never have trusted equations. the numbers i have told you are numbers from people running those setups. if you want more proof you have a motor that 175 hp at the prop(actually yours may or may not be you should look up where your motor was rated from crank or prop) anyways your hull weighs around 850lbs. Also your motor is a tad lighter than mine. The best number i have gotten from mine is 67mph @ 5500rpms w/ a 27srx(3blades). my boat weighs roughly 780lbs. the motor at the time put about 140hp to the prop. once you get your boat in the air it actually packs air better than mine with its extra ft of hull so it is usually faster by 1-2mph w/ the same motor. your boat can do a good bit more than 71mph assuming the motor is healthy.
  5. #50
    Oct 2013
    That's what I thought to. I just guessing would say 75 would prob. Be about it. And about that nose cone low water pickup. It's made out of extremely hard plastic and is bolted to the lower unit. A friend gave it to me and it has worked great. I'm not looking to dial mine down to the .00 but just want it to do the best I can with what I have short of trading my props around. Im A workin dad of two, just an ol country boy. I don't have a lot of money but I have all I need and more than some thanks to The Lord.
  6. #51
    Oct 2013
    Here's a close up.
  7. #52
    Jul 2013
    Athens, TN
    yep id say thats were your limit will be between the case and limited prop selection. the good news is the trophy is one of the best recommended for a fishing prop for our type of boats. but if you ever do get a chance to get it coned id go for it.
  8. #53
    Oct 2013
    Are they welded on?
  9. #54
    southast ark
    If I am looking at the pic of your lower correct that whatever it is bolted to theeading edge ....I assume it's some type of cone. Could very possibly be causing you problems. If that is disrupting water flow or moving any that would play havoc on handling
    Laser 1550 ...under construction with a serious weight loss
    Motor 2.4....undecided on hp yet
  10. #55
    Jul 2013
    Athens, TN
    yes they are welded on and the old water intakes are filled resulting a case that looks like this. this brand is a bobs nose cone.
  11. #56
    Quote Originally Posted by 1FASTLASER View Post
    That's got to create some ugly water for a prop to run in.
  12. #57
    Jul 2013
    Athens, TN
    Ya it looks like it has a large lip that can't be good for the flow. pretty cool idea for a small engine for something that needed to run shallow like a swamp etc.
  13. #58
    Oct 2013
ID:	285240Click image for larger version.
  14. #59
    Jul 2013
    Athens, TN
    wanna show a picture of it from below? as mentioned above that lip on it causes drag and will slow you down.
  15. #60
    Oct 2013
ID:	285245Click image for larger version.
ID:	285243Click image for larger version.
