Results 1 to 15 of 19
    Feb 2011
    Darlington, SC
    22' stoker video (and opinion)
    Alright all you Stoker guys. Here is a video of the back of the boat. Can anyone tell me if the boat is running right boat wise not engine. No jack plate, SRX 29" DAH labbed with a little cup but not much (confirmed with prop shop) , 6300 RPM's and 79.4 on the GPS. You can hear right at the end of the video the increase in RPM's. when that happens the trim gauge (if correct) is two needle widths above 1/2. Basically the boat drops the bow and looses speed. I can slow down a tad, bump the trim down let off the gas and it'll hook back up and carry the bow better. This video was shot with just me in the boat and 40 gallons of gas. Any guidance is greatly appreciated.
    http://youtu.be/hZQjSyV_fNo
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    The small skeg on the v8 case is not helping anything but do you have a torque tab on it?
    In this video it doesnt look like it has a tab but its hard to see.
    http://www.youtube.com/watch?v=vuJsamQyDcQ
    Also the 29srx is 14-1/4" diameter so they do not like higher engine heights. My chopper II 30p was 14.5 and it was 8mph faster then my SRX at the same rpm and engine height with 2x more bowlift.
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
    Jul 2002
    Las Vegas, NV
    Where is the propshaft centerline in relation to the bottom of the boat? Looks kinda low to me.
    Have you checked the motor mounts to make sure everything is good there? A bit of movement, even when you rap the throttle.
    Keith-
    Feb 2011
    Darlington, SC
    Yes there is a torque tab. It has power steering so I might be able to get by with a flat zinc, I'd be willing to try it.
Name:	side view of engine.jpg
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    Feb 2011
    Darlington, SC
    Quote Originally Posted by STV_Keith View Post
    It is mounted in the original position and no jack plate, third hole. Mr. Stoker suggested no plate, third hole (if it had been moved) and a Mazco RE3 28". I haven't been able to get my hands on a Mazco yet just the SRX 29".
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    peabody mass
    those v8s have a nice sound!!1
    Jul 2002
    Las Vegas, NV
    Level the propshaft with the bottom of the boat and use a straight edge to come off the last foot or so of the center sponson and see where the center of the propshaft is in relation to that.
    Keith-
    Feb 2011
    Darlington, SC
    Quote Originally Posted by mach1magnum View Post
    They really do. This one runs great too. Starts very easily usually on the first or second try, no idle issues even with the idle holes plugged, no hesitations anywhere in throttle applications just runs really really well. It is a testament to how well Mr. Stoker builds his engines. I know he has built a ton of them in his life but not that many make it to the east coast so I feel really fortunate to have one of his hot rods especially since I had no idea what I was getting nor did I go searching for one of his boats.
    Funny how I ended up with it. A friend of mine who loves to spend my money on toys called me one day. He tells me there is a boat beside the road in a little town called Ridgeway, SC (population 313) and that I "needed" to come look at it. Now keep in mind I wasn't looking for a boat in general and I surely didn't know anything about a Stoker nor a Stoker built Evinrude V8. It was 2-3 weeks before I had time to sneak up there and take a look at it. When I did my first thought was, she'll kill me. I wish I had taken a picture of the surroundings. Picture a farm in red clay country then picture a farmers shop surrounded by old grain trucks, new fairly large John Deere tractors and other farm implements and you'll have the setting. Needless to say the Stoker was definitely out of place. In the big scheme of things it was almost a barn find due to the limited audience in this area. We have a really small community of hot boat enthusiasts, albeit an intense group, but nothing remotely close to the West coast crowd. Anyway we worked out the details and I brought it home. On the way home I sent my wife this picture with a note that said "I can't seem to shake this boat off of my ass. If it follows me home I think we'll keep it" and the rest is history. We have really enjoyed it and have met some very nice people we wouldn't have if we "hadn't of kept her".
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    Feb 2011
    Darlington, SC
    Will Do.
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    Feb 2011
    Darlington, SC
    Quote Originally Posted by williamj View Post
    Will Do.
    It measures 2-3/4" give or take a 1/4" below the the bottom of the boat. While I was there I also checked the last 4' of the hull and from all indications it is still straight.
    Thanks for helping!!
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
    A torque tab goes on the skeg not the one on the cavitation plate.
    We weld on the front of the skeg and profile them like a sporty or lightning case. This helps the case stay strait in the water reduces slip and helps handling.
    The stock case (tiny omc skeg) im running on the boat now will lose bite with any positive trim then it tries to blow out and thats on a much lighter boat that does not need any trim!
    you got three things against you.
    small skeg
    no torque tab
    small diameter (doesnt carry well once trimmed)
    good skeg
    crap/scary skeg
    Kevin
  12. #12
    Feb 2011
    Darlington, SC
    Oops, rookie error. I take it you suggest one?
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
  13. #13
    Yea, prep it good and use some epoxy stick. Mine was on for years and when I wanted to take it off I tried to chizzle it off and got scared I was gonna break the skeg so I ground it off.
  14. #14
    lexington, sc
    and i have a mazco re28 you can try if you come to the races on oct. 5th again in the same cove as they were a few weeks ago
    <img src=http://www.screamandfly.com/image.php?type=sigpic&userid=36953&dateline=1479911186 border=0 alt= />
  15. #15
    Feb 2011
    Darlington, SC
    Quote Originally Posted by cptunnel View Post
    Missed you this weekend but I understand duty calls!! I have all ideas I'll be there it's on the calendar anyway...
    William J.
    22 SST Stoker
    300 E'rude V8
    Ported and plugged
