Results 1 to 9 of 9
Thread: need help holes in my boat
09-17-2013, 06:06 PM #1Junior Member
- Sep 2012
- toronto ont canada
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Hey guy's so Iv just bought my first hydrostream. its a 79 vking that needs allot of work, most of the work is simple core and floor work but before I get to that I must fix some holes . There are 6 holes in the boat that are about 1/4 ''in size, and all the holes are in a 1.5 foot area. So my question is can I repair the holes and have the repair areas overlapping each other or should I cut out that section and replace it
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
09-17-2013, 06:41 PM #2
Sounds like an easy fix.Post a picture if you can.But don't cut out a section until you get a green lite from the guys that know glass!!
09-17-2013, 07:10 PM #3
if they just holes then its a matter of using a grinder very carefully and doing the repairs from inside possibly !! Like has already been asked for , some pictures of outside and inside so can ascertain exactly what you have got AND THE BEST POSSIBLE WAY TO REPAIR !!!
09-17-2013, 07:48 PM #4Junior Member
- Sep 2012
09-17-2013, 08:05 PM #5Junior Member
- Sep 2012
09-18-2013, 03:38 AM #6
So are these holes penetrating the gell coat on the outside of the hull?
Wellcraft Nova 230 XL, 300hp Johnson.
Seahawk 45 Sport Fisher, twin 306hp Volvo.
Steadcraft 28, Yanmar 300hp. Sold.
Markline 800, Volvo 300hp. Sold.
Haines Hunter V19, Volvo 170. Sold.
16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
09-18-2013, 06:49 AM #7Junior Member
- Sep 2012
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> yes the holes are right through, the tape is covering the holes because I needed to put it in the water to put it on the jig .it looks to me that there from the inside out, I think it must have happened when the previous owner removed the core
09-18-2013, 02:53 PM #8
i would lay down some glass on the inside of the hull and then replace your core. then flip the boat and finish from the outside and then paint/gel. my vking has such a thin ouside hull that i had to put down glass and some spots were paper thin and i didnt take too much off when grinding. i could see though the hull from the bottom of the boat looking up at the sky. not holes, but clear gel with the metal flake in it and i could see the sun shine thru in spots.
1973 Viper - sold
1978 Viking - sold
1995 XB02
09-18-2013, 05:00 PM #9Wellcraft Nova 230 XL, 300hp Johnson.
