Results 1 to 13 of 13
Thread: 260 parts
    Jun 2009
    texas
    260 parts
    These are some parts that came off a running 260 & drag 300.
    Ecu bracket (w/clip,mounting studs,&adj. screw). $55
    shift linkage bracket. $35
    reed plate (98709-3, 8-10-99) $50
    6 reed cages (7 pedal, reeds need replaced,). $75
    fuel rail,injectors,39lb.reg.(w/spacers&nuts). $300
    throttle arm( w/all the adj. screws). $35
    6- coils & plug wires(w/bolts,holders,&harness ). $75
    air horn (w/mounting bolts,nylon bushings w/washers & throttle stop lever) $150
    39 lb Bosch fuel pump. $65
    throttle linkage for air horn( I think for no spacer, it has an oblong hole
    in one end). $35
    a5 ecu(849849 a5, I ran this for a couple of years without the fuel pump
    lead not working) $450
    cdi box with a a48 chip. $375
    trim relay harness(2-relay- part# hella 960 388-32). $35
    2 switch boxes. $35@
    switch box mounting bracket (w/screws & spacers). $15
    i can send pics if u want . U can reach me at 903-261-5014. Also, the air horn
    has one of the nipples or elbows broke off . And I'm sure the injectors need to
    be cleaned & flowed.
    Jun 2004
    Morgan City, LA
    in one end). $35
    I will take these. Let me know how to pay. Thanks.
    Jun 2012
    Bainbridge, Ga
    What's up chug? I will take switch boxes and brackets and Ecu bracket. Pm me your address.
    Flint River Mafia
    1983 Laser LTV #007 RIP Lloyd Burns
    1994 Mirage RR "The Purple Drip" SOLD
    2002 Laser LTV "SOLD"
    Jun 2009
    texas
    BuddyRoe, pm sent
    Jun 2009
    texas
    Hey Laser, good to hear from you. Pm sent.
    Jun 2012
    Indiana
    I will take reed cages and throttle bracket. PM how you want paid.
    May 2008
    Atmore, Alabama
    PM sent, chug.
    Mar 2011
    Up North
    I will take fuel rail/ injector / regulator set up and the fuel pump. Pm me your PayPal address please.
    Thanks Glenn!
    Dec 2011
    Ludington michigan,on the shore
    Need a good ECU injector harness,wat cha got?
    Jun 2009
    texas
    Aggiestckl , pm sent
    Jun 2009
    texas
    Outasite, I don't have an extra ecu harness
  12. #12
    Jun 2009
    texas
    Everything is sold and a few things are pending, all that is left is the trim relays.
  13. #13
    Jun 2009
    texas
    The repair Cdi box with the a48 chip is back up for sale.
Diamond Marine
