Results 1 to 11 of 11
Thread: 300xs issue
09-08-2013, 07:49 PM #1Scream And Fly VIP
- Dec 2009
- canada
- 35
- 11
- 16
300xs issue
Hey guys I've got a 2012 300xs I'm having trouble with, I can take off hard and get up to speed like normal then after about 45 seconds the rpms drop off and it revs erratically. it seems like it's not getting enough fuel, could it simply be the fuel filter? No alarms are going off and there is 100 hrs on it. I'm going to try a new filter in a few days but wondering if anyone else has had similar trouble, hoping it's simply the filter and it starts starving when it's pulling hard through the filter. Doesn't have troubles when I'm cruising at half speed. Any info/help would be much appreciated
09-08-2013, 09:57 PM #2
May sound irrelavant, but what is it on and do you have the stock cowling? Check the insulation
above the throttle body on the under side of the cowl. It has a tendency to fall off, get sucked into the throttle body and starve the motor of air. Check this first,
09-08-2013, 09:59 PM #3
Anything after that, you will need a DDT and a gauge to check the fuel rail pressure and air pressure.
09-08-2013, 10:20 PM #4Scream And Fly VIP
- Dec 2009
- canada
- 35
- 11
- 16
Will do, stock cowl, thanks, plan on getting all the DBR goodies this winter and ditch the ugly stock cowl
09-10-2013, 08:27 AM #55000 RPM
- South Africa
- 576
- 31
Good call on the cowl liner.
Could also be a coil dropping.
Get it to someone with a CDS and do miss fire test at the RPM where it is dropping
09-10-2013, 09:18 AM #6Junior Member
- Jul 2007
- Palmetto, FL
- 27
Sounds like a coil dropping out. Just had this happen on one of mine. Cruising at 3800 rpms it would drop to 3400 then rev back up 30 seconds later. Checked all the plugs and one looked slightly wet and had what looked like a fuel stain on the ceramic part. Changed that coil and everyhting was back to normal. Prior to changing the coil I took apart the VST and pulse pump and checked all the screens and diapragms and everything looked good. Mine is a 2007 though, I thought they had the coil issues worked for the newer ones.
09-13-2013, 12:37 AM #7Scream And Fly VIP
- Dec 2009
- canada
- 35
- 11
- 16
09-13-2013, 02:02 PM #8
NICE!!
Yeap, sounds like a cheap fix, Good job
2001 Velocity 220 - 300xs by DBR - Sold
2001 Motion 25, 03-250xs's
09-13-2013, 06:07 PM #9
Fyi- those filters can be found for under $20 each on ebay, stock up when you find them.
glad to hear you got it right.
09-16-2013, 12:19 AM #105000 RPM
- South Africa
- 576
- 31
There is a pirate version of those filters that you need to stay away from.
Buy the Merc one then you know you are safe, they are expensive but not worth the hassles of the cheaper ones
10-27-2013, 08:26 AM #11New Member
- Oct 2011
- Norway Europe
