Page 29 of 39 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 421 to 435 of 574
  1. #421
    Jul 2013
    Athens, TN
    Hey have you had a chance to test the vent hole effect on a loaded takeoff? If you did did it help?
    1984 17vee Bullet w/1985 Johnson 150gt (bob's nose cone, hydrodynamics custom 8in. jackplate, custom skid plate and foil, and 26p trophy plus) currently 70mph tournament loaded.
  2. #422
    Mar 2012
    floral city florida
    Quote Originally Posted by south599 View Post
    Oh yes it did help once I let my motor down a little. Mine was too high the day Mike and I went out and my prop/s lost grip bad on breakover. However I'm no longer "stuck" to the water. It's hard to believe that without one the holeshot suffers on my boat.
    I also had a severely retarted low speed/idle timing issue, and need new plugs. I have my cherry picker together now and have the area under the back of my boat prepared but I haven't gotten around to changing out my Jackplate as of yet. I've just not had time. Also I wanted to wait to be sure I didn't want to take her out one more time before changing out the Jackplate. I also have one other problem, due to my lack of a shed or Garage, my cherry picker is inside my home. I'll need help to get it outside, lol!
    1986 20 ft. 8 in Shadow Tunnel Vee
    86 Rude XP 200 Looper
    10" Quicksilver Para - Lift Hydraulic.
    Hoss 15 x 28p. HPD & 14 & 3/4 x 27p. Yammie Drag 4
    Ron Hill Custom 15 x 28p. 4 Blade O/T Cleaver, Mazco 15 x 28p. 3 blade Cleaver
    Hydromotive Intimidator Q4 15 x 27p.
  3. #423
    Beautiful Lutz Florida
    Quote Originally Posted by Corona Mike View Post
    One Thing About It...If I Don't Figure It Out, Well Sleepy Hollow Has Cold Beer So I Can Drown My Sorrow There....Just Checked Their Hours Of Operation So, I'm Good!
    Fixed It!! Was Under The weather Last Monday But, Felt Better Today So, Back To The Lake...110 And Still Pulling Very Hard! Red Boat Makes That Lake Very "Short" VERY QUICK! It Was Fun Though! Mite Go Back With A Charged Battery Tomorrow Afternoon! BTW, Sleepy Hollow Was Open But Didn't Have Food Today...But Had Cold Beer!
  4. #424
    Mar 2012
    floral city florida
    Glad to hear you got it fixed. So, what was it anyway?
  5. #425
    Quote Originally Posted by Allyda View Post
    Combination...Motor To Low And Driver Error!...
  6. #426
    Mar 2012
    floral city florida
    Well, glad ya found the problem. Know what was wrong with mine? Combination of motor too high, water in gas tank, and severely retarted low speed/idle timing. That's why it wanted to stall when I put it in gear. However that same day after changing props over to my HPD (Hoss Hyperdrive -the one I picked up and showed you when you asked if prop on motor was my usual) She did hook up and plane off easier. Anyway lowered 1 inch and no more cavitation until she actually does break over like she's supposed to, however that will all change by next weekend with a little luck that nothing pressing comes up between Wednesday and Friday.
    I have cherry picker together, purchased three 5/16 fine threaded bolts and washers yesterday for motor hook. So now all I gotta do is get the cherry picker outside which I'll have a neighbor help me do, and I'll be changing JP this week. I can't start on it today cause I have obligations but tomorrow and rest of week are mine to work on my boat. I hope to have the new one in before the weekend.
  7. #427
    Mar 2012
    floral city florida
    New Hydraulic Para - Lift Jacplate Installed!
    Well, got my new jackplate mounted and everything bolted up yesterday fella's, and am happy to say everything came out great. The only thing left to do now is to run the wiring and mount the control switch. The best news was all tests indicated my transom is in super condition, and has no wood in it for coring, -yay! I sealed everything up with 5200 outside and in, and am very happy with the results. Of course here are a few photo's of the new JP in place on my Shadow.
    I give special thanks to Corona Mike, for without that motor hook I'd have had a hard time getting this done, thanks Mike!
    Attached Thumbnails Attached Thumbnails 0224141725-03.jpg   0224141724-00.jpg   0224141726-00.jpg   0224141726-02.jpg   0224141725-01.jpg
  8. #428
    Sep 2012
    ladson,s.c.
    Allyda, good job man. Did you have enough steering cable? It looks like its stretch out. We got most of the rigging done in the past few weeks. All is left is the gauges and put the gas tank back in. Maybe in a couple of weeks l'll be ready test and tune.allyda. On your 4 blade prop,do you think that's is one best for fishing load?
  9. #429
    Mar 2012
    floral city florida
    Yes I had plenty of cable and steering was not affected. Now I just have to run the wiring harness and mount the control switch.
    As for fishing props, my best is my 4 blade Hydromotive Intimidator Quad 4 "CR". You don't want the "X", it's the Bravo copy and they work best on 300's. The "CR" is rthe semi cleaver design. Here's a photo of mine:Click image for larger version.
Name:	My Hydromotive Intimmidator Q4 27p. Top View.jpg
ID:	293088Click image for larger version.
Name:	My Hydromotive Intimmidator Q4 27p..JPG
ID:	293089 Best prop I've ever run right out of the box!
  10. #430
    Glad I Could Help...Jack Plate Looks Good!
  11. #431
    Mar 2012
    floral city florida
    Thanks, for everything. Now I just have to run the wiring harness for it and find a way to mount the up/down switch. I'm also contemplating using a gauge with it until I get used to it. Since my motor has a bad trim sending unit, I can use the trim gauge that's currently not in use for the jackplate.
  12. #432
    Feb 2013
    mt holly,nc
    so i managed to burn a piston in my my purple motor(235 x-flow) last friday,probably had a too much timing in it!i never could make that motor perform the way i wanted anyway!for the time being,i have put my flat back gt motor back on.so i picked up a 2.6xp this weekend for a song.has one burned up piston but the block still looks great.came with a new piston and gasket kit.everything is there,except for the original lower.the #1 piston munched a ring and really did a number on the head.i would just as well repalce the head,but these heads are getting really tough to to find,so i might try to fix this one.anybody got any ideas?
  13. #433
    southast ark
    Post some pics up of the head. Sure we can help u make a descision
    Laser 1550 ...under construction with a serious weight loss
    Motor 2.4....undecided on hp yet
  14. #434
    Feb 2013
    mt holly,nc
    will take pics and post as soon as i get back home!
  15. #435
    Feb 2013
    mt holly,nc
    Quote Originally Posted by skeeter91 View Post
    here is the head and offending piston~
ID:	293716Click image for larger version.
