Results 391 to 405 of 574
01-30-2014, 08:23 PM #391
01-30-2014, 08:44 PM #392
01-30-2014, 08:46 PM #3931986 20 ft. 8 in Shadow Tunnel Vee
86 Rude XP 200 Looper
10" Quicksilver Para - Lift Hydraulic.
Hoss 15 x 28p. HPD & 14 & 3/4 x 27p. Yammie Drag 4
Ron Hill Custom 15 x 28p. 4 Blade O/T Cleaver, Mazco 15 x 28p. 3 blade Cleaver
Hydromotive Intimidator Q4 15 x 27p.
01-30-2014, 08:56 PM #394
01-30-2014, 09:27 PM #395
I can see where it would help in that area. As far as I know my looper's running a stock flywheel. I hadn't planned on too many modifications to it though because I want to re-power some day with a Yamaha HPDI 225, or A Merc 2.4 or 2.5. My other choice is a 225 E-Tech. About the only real mod I have planned for my looper is a low water pickup nose cone. I'm gonna need it with my new hydraulic jackplate.
01-30-2014, 09:35 PM #396
1ST. I'm No OMC Guy But, If My Old Memory Serves Me, Didn't Some Of The Older OMC V-6's Have An Issue With A Harmonic Vibration From The Stock Flywheel? If Your Motor Falls Into That Catagory...And I'm Not Sure One Way Or The Other...Then Your Motor Would Be A Perfect Candidate For A Light Balanced Flywheel. There Are A Couple Of Guys That Lightened And Balanced Them On S&F. I Know Gary Williams Had A Couple, Seems Like Greg Dunham Had A Couple. Not Sure Who Does The Work Except For Monty...Gordon Montihu...They Really DO Help The Top Crank Bearing And Top Of The Crank...
01-30-2014, 09:47 PM #397
Mine's an 86 model with the newer style flywheel. I think the one your referring to Mike were the flywheels on the older crossflows pre 1983 but I'm not sure. In any case I wouldn't mind replacing mine with a lighter better balance alternative. Mine's like the one in the photo below.
01-30-2014, 09:55 PM #398
That Sounds Rite...I Just remember From Years Back, Guys Would Hit The Panic Button If They Got Close To 6000! Now, Funny Thing I Heard, Was If You Ran A Smaller Prop, The Motors Were Good At 7000 (+). Just Didn't Want To Stay Between 6000 And 6500 For any Liength Of Time.
01-30-2014, 10:01 PM #3991986 20 ft. 8 in Shadow Tunnel Vee
01-31-2014, 09:18 PM #400Member
- Sep 2012
- ladson,s.c.
- 78
Sorry about the out break last night . Al left a pm and said that he was sorry that he did not know that I was really wanting to buy the props? All I can say is ! The good news is I got all my things to finish the shadow and will start first thing tomorrow and can't wait. I will post some photos Sunday to show the progess. Mike are you coming to bucksport for outlaw race in june?
01-31-2014, 10:13 PM #4011986 20 ft. 8 in Shadow Tunnel Vee
01-31-2014, 10:34 PM #402
Kind Of Depends...IF I Go To The Allison Rally, Probably Not. Also Depends On How The Rucker Race Goes...I'm Going To Try Running The 1600# Class With The XB02' The XR02 Doesn't "Fit" In Classes As Well As The Bass Boat With My Motors...280's Are Strong But A Drag On Compression....It's No Match. The Boat Would Make Up For Some Of It But, The "Driver" Would Cost It So...I'll Run My Little Ol' Bassin Boat...It Ain't Skeered!
02-02-2014, 08:30 PM #403
Great Weather Today!!! Nice Meeting Allyda..."Hot Rod" Ran Like A Bucket Of $hit But...I Can Fix It...Wrenches/Props/New Driver...I'm Sure It's Simple! Great BBQ And COLD Beer! Can't Beet That...What Month Is It?....
02-02-2014, 08:47 PM #404
Yea it was a great day Mike. I did make that one good run. There was still a little more in her too. Forgot my gps so don't know how fast I was going but I know I was movin. I think after I change out my jackplate and clean out my fuel pickup in my gas tank my issues will be solved. I do have other props (7 in fact) however that yammie drag didn't do too bad. It was mostly the prop catching too much air just before breakover. That's why when I played with the trim I finally got her up. I'll see if that photo came out ok and if it did I'll post it. It was a great day none the less. Busy at the ramp though, lol!
02-02-2014, 08:55 PM #405
